3DMouse gaming videos
Hypersonic
Post by Hypersonic » Fri Jun 19, 2020 9:41 pm
Made a webpage awhile back with many playlists of YouTube videos all with 3DMouse gaming. I believe all are 4K 60. Many of them are 90's games. A few newer ones which are all Valve productions (Portal 1, Half Life 2, Left for Dead 1.) I still have alot more to upload sitting on my harddrives that I need to upload (ISP has fast downstream but slow upstream.)
https://sites.google.com/view/3dmouse-gaming/home
3DMice are still my favorite device to game with!
imperativeoz
Re: 3DMouse gaming videos
Post by imperativeoz » Tue Aug 25, 2020 7:15 pm
How di you get this done? I want to use the 3Dconnexion SpaceMouse Pro Wireless with Call of Duty warzone.
Hypersonic
Post by Hypersonic » Wed Aug 26, 2020 6:44 am
I created XML files for each of the game engines. Luckily the engines did support controllers. I've haven't tried Call of Duty Warzone, but it might be possible. https://www.gameskinny.com/lmlin/how-to ... zone-on-pc
imperativeoz
Post by imperativeoz » Mon Aug 31, 2020 7:38 am
Thank You!. Is there a detailed guide (step by step) to create these Xml files?
Hypersonic
Post by Hypersonic » Mon Aug 31, 2020 4:00 pm
There might be some good guides, but this is what I usually do
Copy JoystickTemplate.xml from
%programfiles%\3Dconnexion\3DxWare\3DxWinCore64\Cfg
then paste here
%appdata%\3Dconnexion\3DxWare\Cfg\
Then rename the file to identify that app/game that it's for (retain the .xml suffix)
Open it up with a text editor and edit these attributes in
<AppInfo>
<Name>gameName</Name>
<ExecutableName>gameExecutable.exe</ExecutableName>
Before you had to edit the device entry specific to the model 3Dmouse you were using, but now it seems that you can just edit one device entry that applies to all models.
<Devices>
<Device>
<ID>ID_Standard_3D_Mouse</ID>
Usually there's setup in the game itself, typically in the in-game menu.
