Spaceball 4000 FLX and Inventor (10sp3a & 11sp2)
I have 2 Spaceball 4000 FLX's - 1 at home with Iv10sp3a & 1 at work with Iv11sp2. The 2.8.2 driver will not load correctly for either platform - the toolbar is dead within the program, eliminating all customization. I also get a load error every time I start my computer at work. The "new hardware" balloon shows up, along with an error dialog stating that the "coinstsb.dll" file is missing. All I can do is cancel out of this, and the "hardware loaded improperly" balloon then lights up. I've tried re-installing the driver numerous times at both locations with no luck. OS is XP Home & XP Pro. Any ideas?[/img]
The download is nothing more than an .exe file - there's no way to 'open' it. I did at least copy the missing .dll from my home computer, where I don't have the errors on start-up. Hopefully, that will solve that problem. I'm still very curious as to why the toolbar commands are inoperable in Inventor - it works just fine with SolidWorks & AutoCad.
Hi pgwaltney
You should try to unzip, as Fred proposed. Use Winzip or WinRAR, but not ZipGenius, as ZipGenius won't uncompress the file.
Afterwards proceed as described by Fred with the uncompressed files.
agoenczi
Apparently I'm missing something. The driver download (2.8.2) available on this site is an .exe file. Whether I zip it or not, it is an install only. All I can do is run it. Is there another software file you're referring to?
Copying the missing .dll file did solve the start-up errors at least. I did notice something - the Inventor help files included with this driver all refer to the Spacepilot controller. Don't know how I missed that before. I guess the question is - will this thing just not work with Inventor?
Hi pgwaltney
The SpaceBall hasen't any support in the Inventor add-in. The README applies for the SpacePilot only in the version v2-8-2 of the 3DxSoftware. The later versions of the 3DxSoftware have support for the SpaceNavigator, SpaceExplorer and SpaceTraveler but unfortunately not for the SpaceBall (-s).
agoenczi
lynnsaunders
I have been through this thread and cannot get past the missing file named coinstsb.dll.
Any help would be appreciated.
I am trying to use a flex 4000 with rs232 interface through a usb-rs232 adapter. The adapter shows up in Device Manager as COM3. When I plug in the 4000, I get a baloon that says "spaceball 4000 flx found" I downloaded drivers 2.8.2 today.
Lynn Saunders
Lynn Saunders
