for BodyPaint 3D R3?
Hello everybody,
Can you tell me where I can find Plug-In for BodyPaint 3D R3 ? it's not in my components fold,and i know 3Dconnexion devices is support it.
THX for reply!
THX for reply!
Dear xfile2k
There is no 'Plug-in' per se for BodyPaint 3D R3. It would just use the normal 3DxWare drivers that are installed with 3DxSoftware for 3Dconnexion mice.
You may find the drivers on the 'Driver Download Page' under the 'Support Menu' on our 'www.3dconnexion.com' web site.
Sincerely,
Bryan
Sincerely,
Bryan
Dear unlord213
Exactly what version of 3DxSoftware are you using?
(In the '3Dconnexion Control Panel', look for the 'About' Item under the 'Help" Menu.)
What computer do you have?
What version of BodyPaint are you using?
What operating platform, operating system are you using?
Does your SpaceNavigator work okay in the Jet Demo?
(Start, Programs, 3Dconnexion, 3Dconnexion 3DxWare, Demo, Jet Demo)
Behavior of BodyPaint 3D Demo - Release 3 10.504
Dear unlord213,
I'm not sure what behavior Body Paint has programmed their application to take from the input of our device. It does look as though our device is working properly as you have experienced in the Jet Demo. I do not know of any particular settings that Body Paint requires. I would not be too surprized if the demo did not take advantage of our device. Most often the lite version of applications do not. You may want to contact your Body Paint Support and/or Help Features.
Sincerely,
Bryan
Sincerely,
Bryan
Enable Only the Motions You Want
Dear voodoofox,
In the 3Dconnexion Control Panel, under the Advanced Settings Tab, you can pick and choose among the six different motions for the ones you want activate at any one time.
Sincerely,
Bryan
Sincerely,
Bryan
This, for me, is partially correctduvet wrote:ok I could get it workI just asked my friend how to activate it.
1 go to Window> Space Mouse > SpaceMouse Dialog
2 check "Enabled" box
My setting was enabled already but after I uncheck and recheck the box, it worked!
hope this helps
I need to open the SpaceMouse Dialog window to activate the device, but the device stops functioning as soon as I close this window. I need to keep the SpaceMouse Dialog window open all the time.
