The wrist pad on my SpaceExplorer is losing it's finish. It's peeling off. Is it possible to get a replacement pad or do I need to just peel it all off?
Thanks..........Bill
Parts available?
wrist pads have a smooth, finely textured rubber surface
dear cwilliamrose,
The wristpad I have on our SpaceExplorer is a smooth, finely textured rubber surface.
You may be just be dealing with a protective covering used for shipping.
If you think otherwise and it appears to be some sort of defect and your device is still under warrantly, call our help desk, 800 344 1609.
Sincerely,
Bryan G.
Sincerely,
Bryan G.
cwilliamrose
Re: wrist pads have a smooth, finely textured rubber surface
I believe this is what is coming off. There's a shiny plastic surface underneath. See image;Bryan wrote:dear cwilliamrose,
It was purchased 7/29/07. Probably well past warranty. That's why I was thinking to replace the pad -- if possible...........BillIf you think otherwise and it appears to be some sort of defect and your device is still under warrantly,
cwilliamrose
Hi Bill,cwilliamrose wrote: It was purchased 7/29/07. Probably well past warranty. That's why I was thinking to replace the pad -- if possible...........Bill
the warranty for the SpaceExplorer is three years. So you are still within the warranty period.
cwilliamrose
