Different library builds for Visual Studio versions?
wezrule
Post by wezrule »
Hi
In the Software SDK section, there is only 1 link to an SDK version, and that appears to have a dependency on Microsoft.VC90.DebugCRT v9.0.21022.8 which is a Debug CRT library from Visual ++ 2008.
We use Visual Studio 2010, and unfortunately cannot resolve this dependency. Generally when distributing library files, there should be different versions built from Visual studio VC9, VC10, VC11 etc
Is there a way to get a hold of these, that I may be unaware of?
Regards
Wesley
fhernoux
Re: Different library builds for Visual Studio versions?
Post by fhernoux »
Exactly the same here. I fought all the day long with this problem and tried to figure out a solution, but impossible.
I'm also working with visual studio 2010, and the examples work only in release mode with visual2010 not in debug...
I'll try to install VS2008, but I would also have prefered on 2010 for differents reasons.
Regards,
Franck
primusdata
Post by primusdata »
Hello
I'm not able to get it work with visual C++ 2012, I would need only a very simple solution, open the 3dmouse, read the events, close the 3dmouse.
Has anybody an easy little example for this without all the overhead?
Martin
DKMihm
Post by DKMihm »
it didn`t work in vs2010.it corrupted when the program run!
SiGetEvent,this function run out!
hint:
siappdll.dll!1000d6ea()
can someone help?
KalleKoenig
Post by KalleKoenig »
"Bump and +1"
We recently switched to VC10, and we don't want to redistribute the VC8 redistributables to our customer to get our software running. So I also kindly ask for vc10 builds of the .lib files.
Cheers,
Kalle
Zarlox
Post by Zarlox »
Sample are made to work with dynamic CRT form VS2008.
Just go into the same project properties and :
1. Go to C/C++ -> Code Generation. Change the runtime library to the static one (multithreaded [debug])
2. Go to Linker -> Input. Change the siapp.lib to siappMT.lib (and the debug one too of course).
Then the samples will work fine.
The SDK library can also be used in different VC++ version without problems.
