maya 2009 can't load the plugin file
OS Win8.1 64bit, maya2009 SP1 can't load 3DxMaya.mll ."// Error: The specified procedure could not be found.". I have tried in both 32bit and 64bit.
Re: maya 2009 can't load the plugin file
Hello my88036 -
A permissions mis-match can cause this error. Win 7 and 8 require an add-in to have the same permissions level as its application.
If Maya 9 was installed using 'Run as administrator' the 3DxWare installation will need the same permissions.
If Maya is using elevated permissions [Run as administrator] :
With Maya closed, right-click the 3DxWare installer [3Dxware64_v10-1-4-R1818.exe] , choose "Run as administrator" and choose Modify - Repair.
If administrator permissions are the source of the error, that will correct it.
If there is still a problem, check that the plugin [3DxMaya.mll] is present in your Maya plugins folder.Check the path for your Maya installation -ie
C:\Program Files\Autodesk\Maya2009\bin\plug-ins.
Babara
Babara
