Unfortunately this doesnt work out either.
I have:
1. Installed 3dxWare 10.2.1
2. Created a Application specific XML in C:\Program Files\3Dconnexion\3DxWare\3DxWinCore64\Cfg (See below)
3. Deleted the 3dconnexion entrys from C:\Users\<user>\AppData\Local and C:\Users\<user>\AppData\Roaming
When the Application is started I can use the 'Standard'-Button to configure V3DK_1 to my AppCommand. But its still impossible to choose the AppCommand from the list of available commands.
My Application specific XML:
(c) Copyright 3Dconnexion. All rights reserved.
$Revision: 10997 $
<AppCfg Default="true" xmlns="" CfgFormatVersion="1.1" ThisFileVersion="1.1">
<AppInfo>
<Name>MyApp</Name>
<VersionRange>
<Min>1.0</Min>
<Max>1.0</Max>
</VersionRange>
<ExecutableName>*.*</ExecutableName>
<ApplicationIcon>3Dx.ico</ApplicationIcon>
<Transport>S80</Transport>
<SendDeviceChangeEvent>false</SendDeviceChangeEvent>
<IgnoreMouseWheelInertia>true</IgnoreMouseWheelInertia>
</AppInfo>
<CfgProperties>
<Access>
<ReadOnly>true</ReadOnly>
<AllowInheritance>true</AllowInheritance>
<Hidden>false</Hidden>
<Ignore>false</Ignore>
</Access>
<Grab>None</Grab>
</CfgProperties>
<Settings>
<ResponseCurve>1.7</ResponseCurve>
<ScaleX>4.00</ScaleX>
<ScaleY>4.00</ScaleY>
<ScaleZ>4.00</ScaleZ>
<ScaleRx>4.00</ScaleRx>
<ScaleRy>4.00</ScaleRy>
<ScaleRz>4.00</ScaleRz>
</Settings>
<ButtonActions>
<!-- App Handled Actions -->
<ButtonAction Type="App">
<ID>App_ResetYourView</ID>
<Name>STR_APP_RESETYOURVIEW</Name>
</ButtonAction>
<ID>App_ShowYourGUI</ID>
<Name>STR_APP_SHOWYOURGUI</Name>
</ButtonAction>
<ButtonAction Type="AppCommand">
<ID>AppCommand_ToggleMode</ID>
<Name>Toggle operating mode</Name>
<AppCmdID>ToggleMode</AppCmdID>
</ButtonAction>
</ButtonActions>
<!-- For each Legacy app, default to showing the 3DxWare Popup menu for the menu key, since it used to show the 3DxWare GUI. -->
<!-- The Base, sends this key to the app -->
<Devices>
<Device>
<VendorID>0</VendorID>
<ProductID>0</ProductID>
<AxisFilter>None</AxisFilter>
<CurrentButtonBank>Default</CurrentButtonBank>
<ButtonBank Default="true">
<ID>Default</ID>
<Button ReadOnly="true">
<Input>
<ActionID>V3DK_MENU</ActionID>
</Input>
<Output>
<ActionID>Driver_ShowDriverGUI</ActionID>
</Output>
</Button>
<Button>
<Input>
<ActionID>V3DK_FIT</ActionID>
</Input>
<Output>
<ActionID>App_ResetYourView</ActionID>
</Output>
</Button>
<Button>
<Input>
<ActionID>V3DK_1</ActionID>
</Input>
<Output>
<ActionID>AppCommand_ToggleMode</ActionID>
</Output>
</Button>
</ButtonBank>
</Device>
</Devices>
<UI>
<ButtonMappingEditor>
<UseApp>false</UseApp>
<SyncFunctionID>204</SyncFunctionID>
</ButtonMappingEditor>
<AdvancedSettingsEditor>
<SyncFunctionID>205</SyncFunctionID>
</AdvancedSettingsEditor>
</UI>
</AppCfg>
