In Creo, it is possible to assign the buttons to do different things, depending on whether you're in Part mode, Assembly mode, Drawing mode, etc.
I would like to assign the SPEED and have it be different in Part mode than it is in Assembly, for example. Right now, if you change the speed in part mode, then switch over to that part's drawing, the speed setting is the same. I'd like to be able to change this. Is this possible?
Windows 7, SpacePilot Pro, firmware v 4.11, 3DxWare 10.4.4, 3DxWinCore 17.4.4.13133
change speed by Creo context?
Re: change speed by Creo context?
Hi lkb3,
sorry. No, currently this is not possible. The speed settings are not "environment sensitive".
