I have a two computers set up with a teamviewer connection (running Windows 8.1 / 7). I have a Spacemouse connected to both machines. How can I set up the Spacemouse devices so that using the Spacemouse on the local machine, I can control, zoom, rotate etc my CAD model on the remote machine ?
I have seen some posts regarding use of 3dConnexion devices over Windows Remote Desktop, however due to our internet speed and possible other issues, the teamviewer connection is much more reliable.
Spacemouse over Teamviewer
ironfist293
Re: Spacemouse over Teamviewer
Hi i'm also looking to make a similar set up and searching for a way to do this. I'll keep an eye on this thread till then. Can you also share your results if you happen to find a solution first? Thanks!Jane S wrote:I have a two computers set up with a teamviewer connection (running Windows 8.1 / 7). I have a Spacemouse connected to both machines. How can I set up the Spacemouse devices so that using the Spacemouse on the local machine, I can control, zoom, rotate etc my CAD model on the remote machine ?
merritt.andrewt
Just responding so I can get a notification when an answer is posted
Did anyone solve this problem?
I am currently using spacemouse pro with Teamviewer remoting into a computer at another location and not able to control the 3D model on the remote computer. Does anyone have a fix for this issue?
