When using spacemouse enterprise , on win 10 with Autocad architecture I can no longer assign the left and right movement to the controller , there seems to be no way to customise it why not? it is running the latest drivers and Win 10 pro is fully patched as well .
does anyone have any ideas on how I can restore full programmability to it.
space mouse enterprise, can no longer assign left and right movement
Re: space mouse enterprise, can no longer assign left and right movement
Hi paul-s,
I don't understand what exactly you are doing. Sorry. Why do you want to "assign" left + right movement? The navigation with the cap of the SpaceMouse should be available right from the beginning. No need to assign something
hi i mean previously you are quite right the cap will just allow movement left and right , however now it does not and none of the presets will allow adjustment . nothing i can do seems to correct it . I have reloaded drivers tested hardware etc all is well but still no left or right movement. zoom is great etc Bear in mind i am for this application in AutoCAD architecture so 2D rather than 3D
cheers Paul
cheers Paul
Hi paul-s,
does this apply to just your AutoCAD or do you have the restrictions in other applications, too?
