After updating to the latest drivers, the radial menu icons dissapeared.
Is it a bug or this is the new look?
Radial menu icons
Re: Radial menu icons
Hi Isarescu,
this seem to be a bug.
Which application are you using? Did all icons disappear or just the application specific? Do you see the same issue with just one application or in all applications?
Sketchup 2020. Just the application specific.
That's odd. Try of deleting your user specific configuration for SketchUp solves the issue. You do that by deleting (or moving to another place) the file SketchUp.xml from your %APPDATA%\3Dconnexion\3DxWare\Cfg folder. (Usually "C:\Users\username\AppData\Roaming\3Dconnexion\3DxWare\Cfg\SketchUp.xml")
Did not solve the problem.
Hi Isarescu,
I recommend to contact our Technical Support Team. Once you got an email reply from the team you might want to send a video of the problem so that we can analyze it.
