I've updated NX 1926 to 1953.
In 1953 all my settings are reset to default.
Is there any way to import the key settings to the new version?
I reconized that the "name" of the key settings is: "NX - no part". If I remember right it as "NX - shape studio" before.
juup
3DxWare: 10.7.0.3248
3DxWinCore: 17.7.0.17687
NX Setting from 1926 -> 1953
Re: NX Setting from 1926 -> 1953
Do you mean this 3DxWare configuration export and import thing?
Or you simply meant NX role?
- 2020-12-18_14h23_31.png (42.49 KiB) Viewed 3175 times
Thank you, but no.
The Import / Export just restore the settings for a new user for known / configured software. The settings are still ok for the 1926 installation but it looks like 3DxWare do not recognize NX 1953 as the "same software" as 1926.
Any way to tell 3DxWare to use the same commands for "different software"?
One thing I have to say is that the 3DxWare version to version compatibility is not good enough as I expected.
In your case, you have to remember or write down the specific workbench/command mapping before your update your driver.
I'm affraid to do this every 6 month when NX get the next major release...
Sounds like the right method to train your 3DxWare customization skill...
Fixed with the new driver 10.7.1
