button values from 3d space mouse
Re: button values from 3d space mouse
Unless I'm missing something in your code, you don't have any Keyboard event handlers.
E.g.,
Private Sub Keyboard_KeyDown(ByVal keyCode As Integer) Handles Keyboard.KeyDown
Me.SetKeyText(keyCode)
End Sub
Private Sub Keyboard_KeyUp(ByVal keyCode As Integer) Handles Keyboard.KeyUp
End Sub
AntonyAlbertAnto
Post by AntonyAlbertAnto »
no I do not have any such code line.
AntonyAlbertAnto
If I am using those code line, will I be able to see the values from buttons.
You need handlers for the button events.
The exact code lines above came from our vb sample code.
You probably need to do something different with the values when you get them. For now, I'd just print them out.
AntonyAlbertAnto
Hi Jwick,
So is there an example for handlers for the space mouse buttons in vb
I'll email a project to you.
I assumed you had it because some of your code looks like it came from it.
Let me know if you don't get it. Sometimes these things get blocked by firewalls.
Well, I tried. Your email server bounced it back. I'll try a link.
AntonyAlbertAnto
Jwick, Did u send me the link. I haven't got an email or link.
I didn't get a message that the link email bounced.
I've now sent you a PM.
AntonyAlbertAnto
Hi Jwick,
Thanks for the link. I was able to see the translation, the rotation and the angle, but still nothing happened when I pressed the buttons of the space mouse. No value showed in the keydown box.
AntonyAlbertAnto
Hi Jwick,
Do I need to assign any function to the button to see the values before running the program?
By default the side buttons are mapped to driver radial menus.
You need to open our GUI when the application is running and map your buttons to actions that send an event to your application.
E.g., if I am running the vbMonitor sample:
I open our GUI (3DxSmartUI - 3Dconnexion Properties),
select my device,
go to the Buttons page,
select a button,
go to the vbMonitor category
select Back View.
When I press the button I assigned Back View to, I get an "8" in the Key Down TextBox.
AntonyAlbertAnto
Hi Jwick,
Thanks I am able to see the values while press the buttons.
Glad you have it working.
If you want different information for those button presses (e.g., "1", "2"), you can create a cfg file for your application.
AntonyAlbertAnto
Thank you Jwick for your support. I am able to the see the values 1 and 2 while I press the buttons.
Thank you
