This is great! so far so good modifier keys act as they should.. even in ZBrush!! -- Question is this a "public" beta? Can we talk about this?
IF so.. you REALLY need to go spread the word with the zbrush folks. and get this hyped up now that it is working again.
Do you guys know if this will also work or has anyone tested with Monterey?
This is all public. The closed beta ended when macOS 11 was released back in November last.
We have not looked at macOS 12 Beta yet but we don't expect any issues. The technology transition happened going from 10.15 to 11.Do you guys know if this will also work or has anyone tested with Monterey?
Just to be clear i’m talking macos 12 not 11
awesome! Just waiting for octane to work with monterey then i’ll report back
So, I ran the Driver install and when complete and after restart, I get the attached error. The problem is that the message described does not appear anywhere in system preferences...my system is managed by my company using JamF, is it possible that is why it is blocked?ngomes wrote: ↑Mon Jul 19, 2021 2:54 am The "beta 19" (revision r3356) of the new driver for macOS was released today, July 19th. The installer is available from the FAQ page linked here. A change history summary is available on the top post.
The keyboard key emulation feature was replaced by a new implementation based on a DriverKit extension. Modifier keys can now be used stand-alone. The memory leak reported by @slbaumgartner should also be fixed.
After installing the driver, ensure the new driver extension is "allowed" in the "Security & Privacy" pane in System Preferences. The system may also launch the "Keyboard Setup Assistant" to select the keyboard. It is safe to simply close the assistant.
We expect to issue one last "beta" build before publishing 10.7.0 as final.
- Screen Shot 2021-07-19 at 10.07.17 AM.png (149.53 KiB) Viewed 40610 times
We can't comment about using JamF since we don't know what it will do.garybart wrote: ↑Mon Jul 19, 2021 7:13 am So, I ran the Driver install and when complete and after restart, I get the attached error. The problem is that the message described does not appear anywhere in system preferences...my system is managed by my company using JamF, is it possible that is why it is blocked?
If you're seeing the warning, then the system extension isn't yet "allowed". The "Allow" button is shown on the "Security & Privacy" pane in System Preferences. This manual step to "allow" system extensions is by design.
So, to be super clear, I confirmed with myIT team that Jamf is in no way blocking the install. There is absolutely no Message or an Allow button shown anywhere in Security and Privacy. I have uninstalled and reinstalled the driver. It is not working. Please help.ngomes wrote: ↑Mon Jul 19, 2021 7:44 amWe can't comment about using JamF since we don't know what it will do.garybart wrote: ↑Mon Jul 19, 2021 7:13 am So, I ran the Driver install and when complete and after restart, I get the attached error. The problem is that the message described does not appear anywhere in system preferences...my system is managed by my company using JamF, is it possible that is why it is blocked?
Just fyi it did show up for me.. as expected. So. it has to be something on your system.. Everything went smoothly.
We can try but note we haven't seeing this before (system extension not available to be "allowed"). In other words, the issue may be isolated to your system. If others are similarly affected, then it should be easier to narrow down what's causing the issue.
Please check the status of the system extensions. Refer to the topic "Examine the Installed System Extensions" in this page.
WOOHOO! Yes!
New driver works GREAT on my M1 Mac mini with Spacemouse Pro with Zbrush.
All the modifiers keys function and the Zbrush default ortho views are nice (tho I remapped some buttons for pinky-thumb ergonomics while sculpting).
Will probably upgrade to Enterprise from Pro for for better ergo and more buttons to reduce the number of keyboard jumps.
Now I can migrate to my new M1 / Big Sur Mac mini
Thanks to the teams who worked on this!
Not for me on Monterey Public Beta.
Also M1 Mini.
Original Space Navigator still works fine but original USB CADMouse and
Enterprise now lost all special Buttons or Modifier Keys again.
When installing I did accept all Privacy Setting changes
(one time it even asked for password)
and restarted.
Sorry to hear that. Mine is on Big Sur 11.4.
Likewise, accepted the privacy requests, which required password, unlocking, accepting. Also it restarted at the end of install.
Don't know.
Restarted again.
Threw out 3DCon in Privacy Settings, killed 3DCon Helper,
opened the driver settings in Mac Settings,
re-allowed the privacy changes,
(even reallowed Automation for 3DCon access to Music App !?)
No change.
Enterprise and CADMouse are back in feature state of first
3DCon Big Sur Beta Driver - before the Firmware Update.
I also tried to repair/erase/update firmware again via PC.
No change.
Restarted again.
No change.
No change.
