bweitzner wrote: ↑Tue Dec 21, 2021 12:06 pm
I don't have experience with other applications that use the space mouse,
If the issue is specific to PyMOL, I suggest getting in touch with the application vendor and request support. Others have had to make small adjustments to support the new driver.
ngomes wrote: ↑Tue Dec 21, 2021 8:51 am
we will be winding down the direct participation of Engineering in this Forum with support for the Mac transitioning to the capable hands of our Technical Support team.
Everything seems to work fine except the fact that the wireless is not working. I have to use the cable. I have macOS Big Sur (latest version). How can I go about fixing the wireless?
shai wrote: ↑Tue Dec 21, 2021 3:25 pm
Check if pairing the device works. If that works but you still can't get the device to operate, then contact our Technical Support team (details here) since there may be something wrong with your device.
marcarch wrote: ↑Tue Dec 21, 2021 1:26 pm
What about MAC-324 and the firmware update?
It's ongoing but it has been determined to be an issue unrelated to the driver and specific to macOS 12.
Yes, you previously said that a firmware update is required.
Hope to have it soon: it's a very annoying issue especially in AutoCAD where 3rd button click-and-hold performs "pan" action.
Wait, I have not tested, is MAC-324 an issue that happens without 3Dx driver installed too? (I suspect so)
Because CAD Mouse should work as standard mouse first, with two 3rd buttons (wheel button and 3rd button), then 3Dx driver should enable all the cool and personalized stuff we use.
That said the Wireless CAD Mouse firmware update/change should be a priority.
marcarch wrote: ↑Wed Dec 22, 2021 4:25 am
When there is no driver, then the advanced mapping features aren't available and the issue isn't reproducible. Basically, the underlying problem is the system interpreting non-mouse button actions as if they were. If all what the device is doing is acting like a standard mouse, then you will not see anything amiss.
Examples of "advanced mapping features" are assigning a modifier key to a mouse action. Say, for example holding down Shift with the middle-mouse pressed down. A regular mouse can't do this.
ngomes wrote: ↑Wed Dec 22, 2021 4:32 am
But I see the issue with standard mouse action:
- Microsoft Edge not closing tabs (middle 3rd button click);
- AutoCAD lagging/jerky behavior after using pan (middle 3rd button click-and-hold). This happens randomly.
There’s no advanced mapping feature associated to them
