Is there any way (even by manually modifying the profile text file) to manually map the Panel button to a user defined button character and still be able to map Pro/E functions using the Pro E user panel?
I'd like to assign the Panel button to one dedicated function for all Pro E files (drawing, part, assembly, etc), and access the Pro E button mapper via the pull down menu.
If I map it using the standard Control Panel I am no longer able to map pro e functions using that toolbar - the profile in the standard control panel overides any mapping.
Is it possible?
marine_man
Mapping Panel Button with Pro/E Button Mapper
marine_man
USe the Button Mapping editor in the 3DxProENGINEER panel.
If you create a macro in the 3DControl panel.
Save it and then open the 3DXproengineer button editor select the 3dxware and drag and drop the macro you created to a button.
Click save, this saves the profile.
Depending which mode you have open you will have to map each so you can use the same function..
If you have a space pilot you can right click on the other unused profiles and disable, so wont come up as an option.
marine_man
Can you map the function to a keyboard command in Pro-E?
If so you can then open up the 3DXware control panel
(Not the one in Pro E) Click on Button Configuration
Select Custom Function
Give it a name
click on the button you previously mapped to the keyboard.
Click save
Now Open Pro E
open the Button mapping
Select 3DXware
you should be able to find the macro
then drag it to the button you want assigned.
Give it a name
Click save
Now Open Pro E
Select 3DXware
marine_man
I may not be clear on what button it is I want to map.
I want to be able to assign a function (in my case, a user created one) to this button:
I'm pretty sure it's not possible via the normal interface, but is there a (admitadly unsupported) way to do it via the text profile file?
marine_man
marine_man
Hi marine_man,
Have you tried using the "3Dconnexion Control Panel" (with Pro/E on the foreground, go to Start menu, Programs, 3Dconnexion, 3Dconnexion 3DxWare and select "Show 3DxWare Control Panel)? Create your custom function -- as Fred suggested -- and select it on the "Panel" button.
Reprogramming the pane buttonl is not possible using the user interface in the add-in for Pro/E.I'm pretty sure it's not possible via the normal interface, but is there a (admitadly unsupported) way to do it via the text profile file?
marine_man
marine_man
