Remote Desktop use of local Space Navigator
Liks
Re: Remote Desktop use of local Space Navigator
Post by Liks »
Thanks for clarifying :wink:
Hope there'll be a solution with microsoft soon.... we can dream... :D
Today as never before, it's very interesting to use spacemouse with rdp.
cmoneil713
Post by cmoneil713 »
Hello!
As others have asked in this thread, I'm looking to get my Spacemouse Pilot working with Solidworks over RDP. I can get everything working except the esc, control, etc keys.
Jwick, I see that you have a base XML file that I should be able to insert in the program files for it to work correctly. Could you post the base file or send me privately in a message?
Tried to send you a PM but as I just created my account it looks like I'm not able to...
Thanks a ton for the help!
Email sent to registered email address
EricV
Post by EricV »
jwick wrote: ↑Mon May 24, 2021 6:45 am Email sent to registered email address
do you sir also have a base xml for spacemouse enterprise (working mainly with autodesk inventor)
still trying to get it to work
thnx in advance
Email sent
EricV
Post by EricV »
jwick wrote: ↑Wed May 26, 2021 3:52 amEmail sent
thank you very much i got that up and running (after i figured out i needed to set default to those keybuttons first :p)
question do you also know how to get that 1 radial button of the cadmouse working with remote or is that just impossible ? (i dont see the option to port it through remote fx)
thnx in advance
What happens when you press the button?
antonynealrobinson
Post by antonynealrobinson »
You might be able to make use of the cad mouse by creating keybaord macros on the client laptop/pc
And creating macros/mapkeys with the same keys on the host pc.
EricV
Post by EricV »
jwick wrote: ↑Wed May 26, 2021 8:53 am What happens when you press the button?
Nothing happens
rda
Post by rda »
Anyone got this working trough two RDP sessions?
Remote client with USB device -> Corporate server -> Workstation with 3Dconnexion driver
In the first session I got the redirection icon on the RDP bar and i can redirect the device, but not on the second RDP session.
Redirect USB over RDP in two sessions.png (9.66 KiB) Viewed 16575 times
I think all three systems have the same settings now.
I cant verify on the corporate server, but as the icon shows up in the first session I think it's configurerend correctly.
rda
Post by rda »
In addition, I can confirm that the remote client can redirect the USB device to the workstation when using a single session instead of two in series.
Surcouf
Post by Surcouf »
I was wondering if the proposed modification of the base.xml might be a solution to get Shift, Control, Alt, Tab-keys of a SpaceMouse working via an HP RGS (zCentral) connection. Or if the addition of the "Driver_*" keyword only applies for RDP connections to the sender.
A connected SpaceMouse is detected on my recently upgraded remote environment (HP zCentral 20.2.0.8624 and 3DxWare 10.7.3), but the mentioned keys still don't work. Although, hitting the shift button 5 times opens the Win Sticky Keys dialog - so the button-press information is transfered to the sender, but somehow missinterpreted.
Changing the base.xml by adding the "Driver_*" Keywords so far doesn't fix the problem.
Thanks or any help.
Surcouf,
PM your file to me, so I can see what changes you made.
antonynealrobinson
Not sure what files you have but have a look at the attached global.xml that I use to get the spacemouse keys working via RDC.
Using notepad++ helps to view in xml format.
Not used the base.xml method but it may give you an idea of how to get it working.
Section 1 setups the keys
Next 4 sections are related to geting then working for the 4 modes I use in NX.
You'll get similar chunks of code for whichever cad system you use.
Trick is to ensure the Name & ID are correct.
Had no joy with the cad mouse as RDC doesn't allow it to pass through to the 3d connexion drivers at the other end.
Ant.
Global.zip
(761 Bytes) Downloaded 551 times
antonynealrobinson,
In the next major driver release, I've implemented a mechanism for global that allows you to specify those button assignments without having to define all those ButtonBanks. ETA TBD.
