Hi Robert,rstadie wrote:Robert,Robert Tupa wrote: Mapping the sketch command to any of my Space Pilot keys does nothing.
Please use the "Customize"-function of SolidWorks, open the "Commands"-tab and move the "Sketch" function which is located under "Sketch" to your toolbar. After that you will find the "Sketch" command in our Button Mapping Editor (located under the category which has the same name as the toolbar on which you placed the command).
This command will work. Please see also my last post in this thread.
I've a similar issue. I can map sketch (Spacepilot using SW 2008) to a button but it does not work.
regards,
Pat.
