3DConnexion PE edition broken?
iwantfatty
Can you install the driver under administrator?
Also temporarily turn off the firewall and disconnect from network while doing this then see if driver starts.
One more thing:
Please open a command window (some people call that DOS window) and try to start 3Dxsrv.exe from a command line. Do you get an error message this way?
If so, please send the error message to:
[email protected]
If not, please switch-on the "Write Log File" (under Extras) function and send the generated 3DxWare.log file to the same address. The file will be stored under the path:
C:\Program Files\3Dconnexion\3Dconnexion 3DxSoftware
One more thing:
[email protected]
iwantfatty
iwantfatty
iwantfatty
Hi!
We will need some more information to find out what is happening.
Please use the steps below to submit your system information.Vista users: Click on the Start button, and type "msinfo32" in the "Search" field at the bottom.
Please also include a logfile:
Please attach the saved files to an EMail and send it to the address that you will find in your forums inbox.
Robert
a. Click Start
b. Click Run...
c. Type: msinfo32Code: Select all
d. Make sure "System Summary" is selected in the tree on the left.
d. Click File, Save and save the file to your desktop.
f. Exit msinfo32Code: Select all
1. Click Start - Run
2. Type: cmd
3. Type: c: [enter]
4. Type: cd "c:\Program Files\3Dconnexion\3Dconnexion 3DxSoftware\3DxWare" [enter]
5. Type: 3dxsrv.exe -log [enter]
6. Type: notepad "%appdata%\3Dconnexion\3DxWare\3DxWare.log" [enter]
7. Save the file to your desktopPlease attach the saved files to an EMail and send it to the address that you will find in your forums inbox.
Robert
Robert Stadie
iwantfatty
iwantfatty
iwantfatty
iwantfatty
