Space Navigator crashes AutoCAD 2007
rstadie
Post by rstadie »
Please try the following:
Copy
C:\Program Files\3Dconnexion\3Dconnexion 3DxSoftware\3DxAutoCAD2007\3dxautocad.arx -> C:\Program Files\Autodesk\Acadm 2007\
C:\Program Files\3Dconnexion\3Dconnexion 3DxSoftware\3DxAutoCAD2007\3DxAutoCAD.chm -> C:\Program Files\Autodesk\Acadm 2007\Help\
Then copy the following folders to your AutoCAD Mechanical-installation:
C:\Program Files\3Dconnexion\3Dconnexion 3DxSoftware\3DxAutoCAD2007\toolbar\icons -> C:\Program Files\Autodesk\Acadm 2007\Support\
C:\Program Files\3Dconnexion\3Dconnexion 3DxSoftware\3DxAutoCAD2007\toolbar\en-us -> C:\Program Files\Autodesk\Acadm 2007\Support\
Then start AutoCAD Mechanical 2007 and click on “Assist – Load Application”
Browse to C:\Program Files\Autodesk\Acadm 2007\ , mark “3dxautocad.arx” and click on “Load”
Then click on close
Does this procedure help?
Robert Stadie
bturner
Post by bturner »
I did all of the above and still have the same problem, fatal error after using device for a few minutes.
bturner
Post by bturner »
Our IT guy came down and ran about 3 different registery/computer cleanup program on my PC. So far (knock on wood) my Space Navigator has been working without crashing in AutoCAD Mechanical 2007.
I'll post updates if this situation changes.
thanks for your assistance.
bturner
Post by bturner »
Well, that didn't fix it either. I still get the fatal error.
rstadie
Post by rstadie »
AutoCAD has the possibility to create dumps after a crash.
Please send these dumps to the address you will find in your inbox.
Robert Stadie
