Blender - Ubuntu - 3dConnexion - Installation and Testing.
Was it easy for you set up your 3d controller in Blender?
No, never did get it going
4
57%
No, just started, still trying but had to come to the forums.
2
29%
Yes, 1st try was all it took.
0
No votes
No, took days of dregging to finally get it going.
1
14%
Yes, but took a few tries.
0
No votes
Total votes: 7
omac
Re: Blender - Ubuntu - 3dConnexion - Installation and Testin
Post by omac »
Hi there,
I just received my Space Navigator 3D mouse. I have Ubuntu 12.10.
I started by trying the x86_64 version of the driver and ran the install script for it as specified. Then when I ran the xcube demo, it complained about a missing library.
libXm.so.3.
I installed spacenavd and libspacenav from the Ubuntu 12.10 repositories, but the Space Navigator doesn't seem to do anything except show the blue light on.
It doesn't replace the normal mouse which I understand is ok.
When I go to the Ubuntu 12.10 repo version of blender, the Space Navigator does not rotate anything. You have a version called NDOF for blender. Why is it necessary to be so different to the point it won't work with the default repository version? Isn't there anyway to make this work with the Ubuntu Repository versions?
omac
Post by omac »
omac wrote:Hi there,
libXm.so.3.
Ok so the libXm.so.3 error was fixed by installing libmotif4.
Then I ran ./xcube, but I got
3DxWare: xdrvlib.c
3DxWare MotionEvent = 0
3DxWare ButtonPressEvent = 0
3DxWare ButtonReleaseEvent = 0
3DxWare CommandEvent = 0
No driver is running. Exit ...
The line "No driver is running. Exit..." bothers me because if the driver wasn't running, if I understand correctly, the blue light on the mouse would not be on.
omac
Post by omac »
libXm.so.3.
3DxWare: xdrvlib.c
./xvalue
3DxWare: xapp.c
3DxWare Root Window=0x000000BD
3DxWare Application Window=0x04200001
3DxWare: xdrvlib.c
The end ..........
Hi omac,
Can you send me the device PID number (see label near the USB plug) by a private message (PM)? Please don't post this number publicly as it is best kept confidential (the PID is a serial number, unique for each device).
omac
Post by omac »
I've got it working with ubuntu 12.10 and blender finally.
Uninstalled the proprietary driver
Here is my /etc/spnavrc
dead-zone=3.5
sensitivity=.5
rm /etc/inittab which only contained the line for the spacenavigator.
installed from the ubuntu 12.10 repository spacenavd libspnav libspnav-dev:
apt-get install spacenavd libspnav libspnav-dev
cd /usr/share/doc/libspnav-dev/examples/cube/
make
cp ~/.Xauthority /root/
service spacenavd start
spnavd_ctl x11 start
./xcube
This installs blender 2.64:
add-apt-repository ppa:irie/blender
apt-get update
apt-get install blender
When I run blender after that, the spacenavigator 3d mouse runs without any other tweaking involved.
While you're at it, have a look at SpaceAR.Drone sources. They show how to use the SpaceNavigator connected to an Android Tablet to remote-control a drone. Very cool.
