Possibility to switch the LCD display of the Spacemouse Enterprise on and off via function key
Re: Possibility to switch the LCD display of the Spacemouse Enterprise on and off via function key
Hi @Ondra0080, you need to check what name appear then you are focused on desktop (click on any empty space on main desktop). It should be default profile with some programs as shortcuts.
Thanx to all here. It took me awhile, as I stopped reading replies, and I was just changing the Explorer_Background file, but once I changed the global file it worked as expected.
I can't believe that this isn't a standard option. I hope someone in "headquarters" reads these posts.
