Space mouse. Assigning X/Y axis to keyborad arrows
AlexGalland
Re: Space mouse. Assigning X/Y axis to keyborad arrows
Post by AlexGalland »
Dear Jim,
Yes, Shift+arrows moves in larger increments than just arrows. i manage to pan but even adding the shift modifier section in my cfg file, it does not apply. Does it apply for you? Were you using opera too or another web utility? Regarding zoom, did you used the Z axis?
I just used your file with a fresh download of Opera.
You can see what is being sent by turning on "Write Log File" under the 3Dx systray icon, the using baretail to watch the end of the log file (%localappdata%\3Dconnnexion\3DxWare\3DxService.log).
AlexGalland
Thanks Jim
kenny113
Post by kenny113 »
@AlexGalland were you able to get it working? If so, would you be willing to share your config file for eSlide Manager WebViewer? Thank you!
bubo4
Post by bubo4 »
Dear Community
We also got a space mouse and we like to use it for digital pathology.
The program we use is Aperio ImageScope. The joystick should be moved forward and backward to navigate the screen and zoom in and out with the left and right scroll wheel and alos have a function for fine zooming.
I have tried to change the xml file but with little success.
Can you help me with this?
bubo4,
PM your XML file to me
bubo4
Post by bubo4 »
Hi jwick!
Unfortunately I am not able to PM you as I am a new member.
Could you write to my email adress and tell me which xml file is needed?
Thank you in advance!!
bubo4 wrote: Thu Sep 22, 2022 11:30 pm Unfortunately I am not able to PM you as I am a new member.
PMs should work for you now. Please try again when you can.
kenny113
Post by kenny113 »
AlexGalland wrote: Thu May 27, 2021 2:26 am Dear Jim,
@AlexGalland would it be possible to PM me your XML used for WebViewer? Thanks!
antonioamr
Post by antonioamr »
Please, someone could help me to use my 3dconnexion like a mouse? I'm not understanding the instructions in this thread.
antonioamr
Hello, Alex. Do you file cfg? I would like to use my 3dmouse like a mouse. I am pathologist and I trying to improve my digital cases.
Many thanks.
AlexGalland wrote: Thu May 27, 2021 1:03 am Hello Jim,
Just done.
Many thanks.
RandyBerghef
Post by RandyBerghef »
Has anyone been able to figure this out yet. We are using Aperio ImageScorpe 12.4.6 and I have 3D SpaceMouse Pro 3DxWare 10.8.10. The only item that I am able to make work with the Zoom in/out by moving the control head backwards and forward. I would like to see if I can get the 3D mouse to pan left/right up and down.
Randy
I have something you can try.
I don't consider it production worthy but if it is useful, perhaps we can use it to convince LeicaBiosystems to add proper support.
PM / email me to try it.
kenny113
Post by kenny113 »
jwick wrote: Fri Nov 04, 2022 10:52 am I have something you can try.
I can’t PM you for some reason, but would be interested in trying your solution. I also have a direct line to Leica’s R&D team, so if it’s usable, I could work on implementing an official solution. Could you please message me? Thanks!
kenny113 wrote: Fri Nov 04, 2022 10:56 am I can’t PM you for some reason,
You can't use private messages until you reach a number of approved posts.
Please try again as it should now work for you.
