3Dconnexion/Blender Beta Feedback
visualgroup
The folder is in the correct place, the plugin is named correctly and I've full read/write access to all folders.
No debug information is displayed in the console window.
The device works correctly with Pro/Engineer, SketchUp, MSOffice, Photoshop etc.
I'm an experienced user of 3DConnexion devices and Blender.
I really hope this can be sorted out, too many people are having similar problems.
this is with debug build "3DxNdofBlender.plug.zip"
Starting blender gives this console output:
maybe this helps to find the cause, output of "FileMon.exe" windows version of strace
"3DxNdofBlender.plug.2.Manifest" and "3DxNdofBlender.plug.2.Config" ?
Button 1 and 2 are dead too
fullname = 'F:\blender3dx\blender.exe'
Shortname = 'F:\BLENDE~3\blender.exe'
Compiled with Python version 2.5.
'import site' failed; use -v for traceback
Checking for installed Python... No installed Python found.
Only built-in modules are available. Some scripts may not run.
Continuing happily.
ndof manager
plugin path=F:\BLENDE~3\plugins\3DxNdofBlender.plug; ndofLib=00000000
17:03:05 blender.exe:500 QUERY INFORMATION D:\wbin\Wintab32.dll FILE NOT FOUND Attributes: Error
17:03:05 blender.exe:500 QUERY INFORMATION D:\Programme\Gemeinsame Dateien\GTK\2.6.9\bin\Wintab32.dll FILE NOT FOUND Attributes: Error
17:03:05 blender.exe:500 QUERY INFORMATION D:\Programme\SSH Communications Security\SSH Secure Shell\Wintab32.dll PATH NOT FOUND Attributes: Error
17:03:05 blender.exe:500 QUERY INFORMATION F:\BLENDE~3\plugins\3DxNdofBlender.plug SUCCESS Attributes: A
17:03:05 blender.exe:500 OPEN F:\BLENDE~3\plugins\3DxNdofBlender.plug SUCCESS Options: Open Access: Execute
17:03:05 blender.exe:500 QUERY INFORMATION F:\BLENDE~3\plugins\3DxNdofBlender.plug SUCCESS FileNameInformation
17:03:05 blender.exe:500 QUERY INFORMATION F:\BLENDE~3\plugins\3DxNdofBlender.plug SUCCESS Length: 790528
17:03:05 blender.exe:500 CLOSE F:\BLENDE~3\plugins\3DxNdofBlender.plug SUCCESS
17:03:05 blender.exe:500 OPEN F:\BLENDE~3\plugins\3DxNdofBlender.plug.2.Manifest FILE NOT FOUND Options: Open Access: All
17:03:05 blender.exe:500 OPEN F:\BLENDE~3\plugins\3DxNdofBlender.plug.2.Config FILE NOT FOUND Options: Open Access: All
17:03:05 csrss.exe:1180 OPEN D:\WINDOWS\WinSxS\Policies\x86_Policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_5f0bbcff\ FILE NOT FOUND Options: Open Directory Access: All Button 1 and 2 are dead too
17:59:51 blender.exe:1476 QUERY INFORMATION E:\NDOF\plugins\3DxNdofBlender.plug SUCCESS Attributes: A
17:59:51 blender.exe:1476 OPEN E:\NDOF\plugins\3DxNdofBlender.plug SUCCESS Options: Open Access: 00100020
17:59:51 blender.exe:1476 QUERY INFORMATION E:\NDOF\plugins\3DxNdofBlender.plugCode: Select all
17:59:51 blender.exe:1476 CLOSE E:\NDOF\plugins\3DxNdofBlender.plug SUCCESS
You can download it from:
http://blendertestbuilds.de/Plugins/ndof/Windows/
But I downloaded the package from blenderbuilds.com. So i do not know if this helps.
Ok, hopefully I can provide help for those on Linux who see this:
When I strace the process I get this line:
So it is looking for the plugins directory in wherever it was run from, in my case a symlink.
My suggestion to those on Linux having this problem is to run the binary directly, instead of from a symlink, until the builds/plugin is fixed. This way it now works for me.
Frank
fp@slack12:~$ blender
guessing 'blender' == '/usr/local/bin/blender'
Compiled with Python version 2.5.1.
Checking for installed Python... got it!
ndof manager
open("/usr/local/bin/plugins/3DxNdofBlender.plug", O_RDONLY) = -1 ENOENT (No such file or directory)Code: Select all
fp@slack12:~$ ls -l /usr/local/bin/blender
lrwxrwxrwx 1 root root 40 2007-08-22 16:18 /usr/local/bin/blender -> /usr/local/blender-NDOF-20070802/blender*Code: Select all
fp@slack12:~$ /usr/local/blender-NDOF-20070802/blender
ndof manager
1 client
3Dconnexion blender plug-in: loaded.
space navigator Windows XP: SOLUTION!
If you have problems getting Blender NDOF run with your space navigator,
download the vcredist.exe (2.6 MB) from Microsoft homepage (The MS Visual C++ Redistributable 2005) and install it.
Now my space navigator is detected when starting blender and the navigator works perfect now!
However, make sure that the mouse pointer is over the 3D Window, otherwise it will not work. I had to reconfigure the buttons and axis of the navigator also (e.g. invert axis and increase speed and the like). Once you are satisfied, save the configuration e.g. as "Blender".
This process was a little bit confusing, but finally worked.
Hope that helps.
klogath
Hope that helps.
klogath
@klogath It did help
Finally it works
plugin path=F:\BLENDE~3\plugins\3DxNdofBlender.plug; ndofLib=01ADE7F0
1 client-
visualgroup
Success! with win xp home
Hi every one.
Thank you for that advise klogath.
Now it works fine and I'm very very happy.
tilt & roll speeds a little slow?
I just started to play with space nav & blender, appears to work flawlessly on windows xp. (I had Visual C++ 2005 runtime components installed and did not run into the issues described by some - btw, isn't that a blender requirement on windows?)
At first glance, the tilt & spin speed seems to be calibrated a little bit on slow side when compared to the panning motions - even when I move the tilt and spin speed sliders completely to the right, the motion seems "slow" relative to the panning speeds left at the default speed setting. Thoughts?
Re: tilt & roll speeds a little slow?
Oh yeah, I guess it is... doh, I completely missed that (official) requirement:twisted wrote:I just started to play with space nav & blender, appears to work flawlessly on windows xp. (I had Visual C++ 2005 runtime components installed and did not run into the issues described by some - btw, isn't that a blender requirement on windows?)
blender.org/download/get-blender wrote: For the Windows build, you may need to install this official update. Vista doesn't need this, but users of older Windows versions should install it if they experience a crash during startup of Blender. Microsoft Visual C++ 2005 Redistributable Package (x86)
Could be. You have a few ways to adjust the sens - use the individual sliders to adjust sens of one axis relative to the others, and the general slider in the "Device" tab for the overall sens. Next releases will probably be more fine tuned.twisted wrote:At first glance, the tilt & spin speed seems to be calibrated a little bit on slow side when compared to the panning motions - even when I move the tilt and spin speed sliders completely to the right, the motion seems "slow" relative to the panning speeds left at the default speed setting. Thoughts?
ettore pasquini
software engineer
3Dconnexion, inc.
software engineer
3Dconnexion, inc.
artfultheory
Correct me if I'm wrong, but since I'm running Vista 64, I should be able to:
1. Install my SpaceNavigator core drivers(*1)
2. Ensure my SpaceNavigator is working with demo apps
3. Download Blender 2.44 NDOF experimental branch(*2) and extract/install
4. Download and install Python 2.5
4. run Blender, with support for my SpaceNavigator!
But it doesn't work. Instead I hit the same dead-end others have reported, which is the Blender initialization completing with:
ndof manager
Conclusion:
There's something wrong with the code, and the SpaceNavigator won't work in my configuration.
Steve, Luke, Ettore, did I miss something? If not, and you don't already know what is up, I've got VSE C++ downloading right now. Please give me your thoughts before I burn any more time on this though.
Shannon
Notes:
1. I assume I don't need to download the plugin(*3) separately and copy it into the Blender folder, although I later tried doing so.
2. Although the installation instructions(*4) at BlenderBuilds reference this plugin, they also reference a version of the NDOF build(*2) for Windows with this plugin included. Also, this thread I'm posting to says
3. Per this thread, the original 3DConnexion builds(*5) are missing some components, and the "Normal" NDOF build(*2) should be used when troubleshooting.
4. BlenderBuilds has various Blender SIG releases, but BlenderFoundation or "BF" posts the widely-accepted and supported stuff. As of this post (BF release 2.45 is current), SpaceNavigator doesn't work in BF builds. Don't bother trying to install the plug-in into a BF folder yet.
5. The seemingly authoritative installation page(*8) at 3Dconnexion's site doesn't mention you must use the NDOF build of Blender, but you must.
6. The announcement(*6) of Blender support for 3D controllers refers to BlenderBuilds releases.
7. The announcement(*7) of 3Dconnexion support for Blender refers to currently beta code
8. The Visual C++ redistributables are required in many cases(*9) for this to work. However, they are included with Vista, and will not install if attempted.
9. The BlenderDev wiki(*10) on this topic doesn't really have any information.
10. There's a long article at (*11) that ends in posters crossing their fingers for support for the SpaceNavigator in Blender 2.45, don't bother reading it.
(*1) http://www.3dconnexion.com/support/downloads.php
(*2) http://mirror.blenderbuilds.com/windows ... _win32.zip
(*3) http://mirror.blenderbuilds.com/plugins ... indows.zip
(*4) http://www.blenderbuilds.com/2007/08/05 ... h-a-prize/
(*5) http://mirror.blenderbuilds.com/windows ... 2_orig.zip
(*6) http://www.blender.org/news/article/3d-device-support/
(*7) http://www.3dconnexion.com/news/press/0 ... lender.htm
(*8) http://www.3dconnexion.fr/solutions/blender.php
(*9) http://blenderartists.org/forum/showthr ... enavigator
(*10) http://wiki.blender.org/index.php/Blend ... dofDevices
(*11) http://blenderartists.org/forum/showthr ... tor&page=3
http://www.blendernation.com/2007/08/13 ... r-support/
As an aside, there's random data on this topic in various places. However, most of it is partial reposts of initially incomplete information. I'm a little frustrated that I took "3Dconnexion Announces Support for Blender" at face value, without reading the fine print (forums). Support really isn't there yet, especially from a documentation perspective, since there are neither consistent nor authoritative installation procedures.
I purchased the SpaceNavigator specifically for use with Blender. Thanks for opening your libraries to a GNU project, and I'm looking forward to the first BF release of Blender that actually implements them. Until that time, I hope the information I've gathered here helps save others some of the time this issue cost me.
ndof manager
Conclusion:
Shannon
Notes:
