Spaceball 5000 software doesn't allow control of the BEEP!
My IT dept load new software and I lost my ability to turb the beep on and off. Am I missing something?
Hello stevenhaggerty,
That is no longer an option in the 3DxWare GUI. The capability is still there though if you want to do some work. The beeps are controlled by a registry setting:
HKCU/software/3dconnexion/3dxware/Disable Beeps (a REG_SZ value)
Set this to 1 to disable the beeps. Set to 0 to have the beeps.
This can be done with two .reg files.
The driver has to be restarted after making this change.
3Dx Software Development
Constant beeping with Spaceball 5000 software
The other issue I have is that the SPaceball 5000 beeps as each application windows that it supports is activated. This means quite a few beeps during the day is this the intended operation? Previous software the Hardware beeped only during logon or logout of windows.
Steve
Steve
Hi Steve,
I believe the beeping is by design. It's quite annoying. I'd turn them off permanently or cut the wire <G>. None of the devices designed in the last 9 years have had beepers. I don't see how they are useful, especially since, it seems, all of our new devices have LEDs. The LEDs are a better way to see if the device is "on".
