SpaceNavigator & Photoshop CS3 = perfect!
Wow.
After one day, I can not imagine anymore working with photoshop without using the spacenavigator to pan, zoom and set the brush-size.
This gadget extremly increases my workflow.
However, since I use a german keyboard layout, to make the brush-size control work, I had to install a german photoshop version, using an english version did not allow to controll the brush size by rotating the cap.
This is a fantastic product for all photoshop artists, 3dconnexion should announce this very prominently on their website and the product specs.
Its easier to toggle keyboard layout
I use CS3 English version, on an English Windows XP, with the space pilot, and have a German layout keyboard as well. Brush resize works fine if I use the XP language bar to toggle keybord layout to English. When I have to type in some German text with Umlauts then I just toggle back to German for the moment.
So its easier than installing a German Photoshop (I also don't like the translations of commands) and still have brush resize via space pilot...
Anyway it a nuisance and I would like the 3Dconnexion people to account for regional keyboard layout in a future driver update ....
Jens Mondry
Hi moonsoft,
We're currently looking at what can be done to support environments with mixed language versions for Photoshop and the keyboard. Until that's available, our recommendation is to use the same keyboard layout language as the localized language for Photoshop. That is, English Photoshop with English keyboard layout for example.
Some background information on why it is important to maintain the same keyboard language layout as your Photoshop software... The 3DxPhotoshop plugin simulates keystrokes to adjust the brush size. Each localized version of Photoshop uses a different set of keystrokes for adjusting the brush size. If the input language for the keyboard does not match the language for Photoshop, it may not be possible to simulate the required keys since they will have a different scan code that may not exist on that keyboard layout. The only sure way to avoid this issue for now is to match the keyboard input language to that of Photoshop.
CS3, WinXP english on a Macbook Pro with danish keyboard
Brush size doesn't work here either.
Sincerely
JonAngelo
Sincerely
JonAngelo
Please see this post on using Photoshop CS3 with 3DxSoftware v3.5.6 on Windows.
viewtopic.php?p=7596#7596
I have just received spaceTraveler with 3.5.6 driver and I cannot change the brush size in photoshop cs3 (os vista).
Photoshop is english, however my vista is not (I am also using several keyboard encodings, tho primary is english). I was able to set shortcut with photoshop at first run, I have also checked the directory mentioned on the link above and it should be all OK.
The other programs I use, work as advertised.
I assume you're able to navigate and only the brush size adjustment is not working? One thing to note is that the shortcut you specify is tied to the keyboard encoding. If you change the encoding, then the brush adjustment will stop working.
Try this.
- Start PS and set the encoding to EN
- Change the shortcut for 3DxPhotoshop plugin to Alt-Shift-Ctrl-H
- Restart PS and make sure the kb is set to EN
- Try adjusting brush size
Try this.
