I'm just starting to try and get some SpaceExplorers working on AIX 5.3.
I installed 3DxWareUNIX v1.2.11, our oslevel is 5300-03-00, and the prerequisite filesets are all OK. Rebooted after installation with the device plugged in like the box leaflet says.
Attempting to run xcube as a normal user complained that no driver was running. Attempting to start the driver with
3dxsrv -d usb
Like some other forum posters, logging in as root to CDE helped somewhat - the driver started after about 30 seconds, the device lights came on and it was functional with the demo apps and Catia V5. Logging back in as a normal user after this did not change the situation, except the device lights stayed on.
Debug output from normal user login is as follows:
3DxWareUNIX V1.2.11 ID 3213 log file
Process ID: 360614
Time: 2007-10-10 11:15:12
Machineinfo 1: Systemname=AIX, Nodename=talrsdc1, Release=3
Machineinfo 2: Version=5, Machine=00C5498C4C00
Runlevel-Info: . run-level 2 Oct 10 09:50 2 0 S
[2007-10-10 11:15:12] 3dxsrv.c,651: displayname = :0.0
[2007-10-10 11:15:12] auth.c :: authGetUser(), FOUND: user = peter, id = dt, line = lft0, pid = 323778, host = , type = 7
[2007-10-10 11:15:12] auth.c :: authGetUser(), FOUND: user home = "/home/peter"
[2007-10-10 11:15:12] 3dxsrv.c :: startupCommandLine(), authGetUser(), user=peter
----PeterH.
