jerryti
Posts: 11 Joined: Thu Feb 14, 2008 5:27 am
Post
by jerryti » Thu Feb 14, 2008 5:35 am
Did anybody has succes with SpaceTraveler & WildFire IV?
rstadie
Posts: 777 Joined: Tue Sep 25, 2007 6:18 am
Post
by rstadie » Fri Feb 15, 2008 3:56 am
Hi jerryti,
Movement should work fine. Our Plug-in for button mapping needs to be updated until it works with Pro/E 4.0 - so currently button mapping will not work as desired.
Robert Stadie
jerryti
Post
by jerryti » Fri Feb 15, 2008 5:02 am
What are You talking about? What "movement"? It's didn't even show in WildFire at all
rstadie
Post
by rstadie » Fri Feb 15, 2008 7:52 am
Do you use a "Student Edition" or something similar? With the normal version you should be able to make use of the movement which is integrated directly into Wildfire as long as your driver is started.
Robert Stadie
jerryti
Post
by jerryti » Fri Feb 15, 2008 8:08 am
I'm using Commersial Version, build F000
rstadie
Post
by rstadie » Fri Feb 15, 2008 11:10 am
And our demos work? (e.g. the Cube3D demo). Which driver version are you running with which operating system?
Robert Stadie
jerryti
Post
by jerryti » Fri Feb 15, 2008 11:17 am
Not just Cube3D, all programs, including WildFire II & III, but not WildFire IV
rstadie
Post
by rstadie » Fri Feb 15, 2008 11:28 am
I need your driver version and os to see if there is perhaps a problem. An old version of WF4 works fine here with windows xp.
Pro/ENGINEER Date Code: C010
Which config is loaded into the 3DxWare Control Panel?
Robert Stadie
jerryti
Post
by jerryti » Fri Feb 15, 2008 11:33 am
Driver 6.5.5. Pro/Engineer, like I already mentioned to You, is F000 (First release). C010 is pre-Production, kind beta test
rstadie
Post
by rstadie » Fri Feb 15, 2008 11:39 am
Do you use XP or Vista?
Robert Stadie
jerryti
Post
by jerryti » Fri Feb 15, 2008 11:46 am
XP, SP2
rstadie
Post
by rstadie » Fri Feb 15, 2008 11:49 am
Ok. I will come back to you as soon as I have news on this. Have you already contacted PTC? What do they say?
Robert Stadie
jerryti
Post
by jerryti » Fri Feb 15, 2008 11:55 am
PTC blaime You, they said Your driver not updated for WildFire IV
rstadie
Post
by rstadie » Tue Feb 19, 2008 10:35 am
Do you use XP32 oder XP64?
Robert Stadie
jerryti
Post
by jerryti » Tue Feb 19, 2008 10:41 am
Why You not just admit, that You don't have any solution whatever, instead of asking questions, which dosn't make any sense? Or at least put all of them together, not each e-Mail different question
