I just started using my new SpacePilot. It is great except for the lag between button pushes and the 3D lever working again. Anyone else have this?
I am using it with Delcam's Shape and Mill. Running XP64.
Wil
SpacePilot Lag
Here is what the log file has in it. Maybe Staff can help me. I tried email tech support but the form kept returning errors.
9:23:4.985: s80trans:UdTransSendEvent: Error: Buffer full. Ignoring new event type=2. Resignaling last event.
9:23:5.000: s80trans:UdTransSendEvent: Error: Buffer full. Ignoring new event type=2. Resignaling last event.
9:23:5.016: s80trans:UdTransSendEvent: Error: Buffer full. Ignoring new event type=2. Resignaling last event.
9:23:5.032: s80trans:UdTransSendEvent: Error: Buffer full. Ignoring new event type=2. Resignaling last event.
9:23:5.047: s80trans:UdTransSendEvent: Error: Buffer full. Ignoring new event type=2. Resignaling last event.
9:23:5.063: s80trans:UdTransSendEvent: Error: Buffer full. Ignoring new event type=2. Resignaling last event.
9:23:5.078: s80trans:UdTransSendEvent: Error: Buffer full. Ignoring new event type=2. Resignaling last event.
9:23:5.094: s80trans: Memory map underflow error
9:24:8.566: UdUi->Help: UI Help Called
9:24:42.468: s80trans:UdTransSendEvent: Error: Buffer full. Ignoring new event type=2. Resignaling last event.
9:24:42.484: s80trans:UdTransSendEvent: Error: Buffer full. Ignoring new event type=2. Resignaling last event.
9:24:42.499: s80trans:UdTransSendEvent: Error: Buffer full. Ignoring new event type=2. Resignaling last event.
9:24:42.515: s80trans:UdTransSendEvent: Error: Buffer full. Ignoring new event type=2. Resignaling last event.
9:24:42.531: s80trans:UdTransSendEvent: Error: Buffer full. Ignoring new event type=2. Resignaling last event.
9:24:42.546: s80trans:UdTransSendEvent: Error: Buffer full. Ignoring new event type=2. Resignaling last event.
9:24:42.562: s80trans:UdTransSendEvent: Error: Buffer full. Ignoring new event type=2. Resignaling last event.
9:24:42.578: s80trans:UdTransSendEvent: Error: Buffer full. Ignoring new event type=2. Resignaling last event.
9:24:42.593: s80trans: Memory map underflow error
9:24:43.374: s80trans:UdTransSendEvent: Error: Buffer full. Ignoring new event type=2. Resignaling last event.
9:24:43.390: s80trans:UdTransSendEvent: Error: Buffer full. Ignoring new event type=2. Resignaling last event.
9:24:43.406: s80trans:UdTransSendEvent: Error: Buffer full. Ignoring new event type=2. Resignaling last event.
9:24:43.421: s80trans: Memory map underflow error
9:25:59.661: UdUi:TlReadConfigFile: Reading file: C:\Documents and Settings\wil.lambert\Application Data\3Dconnexion\3DxWare\profiles\user00.scg
9:25:59.677: UdCtlTransSendSync: AppName=Delcam, sync->opCode=3, sync->itemCode=12
9:26:0.146: udui.cpp:QueryAppForGuiSync: Calling UdCtlSendSync
9:26:0.146: UdCtlTransSendSync: AppName=Delcam, sync->opCode=1, sync->itemCode=2
9:26:0.161: UdArbitrate: New Target: hWnd: 0x20e00, Class Name: Afx:00400000:8:00010005:00000000:000D0255, AppName (SiOpen): Delcam, ExeName: powershape.exe
9:26:0.161: s80trans: Memory map underflow error
9:26:52.576: udui.cpp:QueryAppForGuiSync: Calling UdCtlSendSync
9:26:52.576: UdCtlTransSendSync: AppName=Delcam, sync->opCode=1, sync->itemCode=2
9:26:52.576: UdCtlTransSendSync: AppName=Delcam, sync->opCode=3, sync->itemCode=10
9:26:52.576: s80trans: Memory map underflow error
9:27:43.726: UdCtlTransSendSync: AppName=Delcam, sync->opCode=3, sync->itemCode=12
9:27:43.726: UdCtlTransSendSync: AppName=Delcam, sync->opCode=3, sync->itemCode=11
9:27:43.726: s80trans: Memory map underflow error
9:27:47.882: UdCtlTransSendSync: AppName=Delcam, sync->opCode=3, sync->itemCode=12
9:27:47.882: UdCtlTransSendSync: AppName=Delcam, sync->opCode=3, sync->itemCode=11
9:27:47.882: s80trans: Memory map underflow error
9:29:9.407: s80trans:UdTransSendEvent: Error: Buffer full. Ignoring new event type=2. Resignaling last event.
9:29:9.438: s80trans:UdTransSendEvent: Error: Buffer full. Ignoring new event type=2. Resignaling last event.
9:29:9.453: s80trans:UdTransSendEvent: Error: Buffer full. Ignoring new event type=2. Resignaling last event.
9:29:9.469: s80trans:UdTransSendEvent: Error: Buffer full. Ignoring new event type=2. Resignaling last event.
9:29:9.485: s80trans:UdTransSendEvent: Error: Buffer full. Ignoring new event type=2. Resignaling last event.
9:29:9.500: s80trans:UdTransSendEvent: Error: Buffer full. Ignoring new event type=2. Resignaling last event.
9:29:9.516: s80trans:UdTransSendEvent: Error: Buffer full. Ignoring new event type=2. Resignaling last event.
9:29:9.532: s80trans:UdTransSendEvent: Error: Buffer full. Ignoring new event type=2. Resignaling last event.
9:29:9.547: s80trans:UdTransSendEvent: Error: Buffer full. Ignoring new event type=2. Resignaling last event.
9:29:9.563: s80trans:UdTransSendEvent: Error: Buffer full. Ignoring new event type=2. Resignaling last event.
9:29:9.578: s80trans:UdTransSendEvent: Error: Buffer full. Ignoring new event type=2. Resignaling last event.
9:29:9.594: s80trans:UdTransSendEvent: Error: Buffer full. Ignoring new event type=2. Resignaling last event.
9:29:9.610: s80trans:UdTransSendEvent: Error: Buffer full. Ignoring new event type=2. Resignaling last event.
9:29:9.625: s80trans:UdTransSendEvent: Error: Buffer full. Ignoring new event type=2. Resignaling last event.
9:29:9.657: s80trans:UdTransSendEvent: Error: Buffer full. Ignoring new event type=2. Resignaling last event.
9:29:9.672: s80trans:UdTransSendEvent: Error: Buffer full. Ignoring new event type=2. Resignaling last event.
9:29:9.766: s80trans: Memory map underflow error
9:33:45.817: UdUi:TlReadConfigFile: Reading file: C:\Documents and Settings\wil.lambert\Application Data\3Dconnexion\3DxWare\profiles\user00.scg
9:33:45.832: UdUi:TlReadConfigFile: Reading file: C:\Documents and Settings\wil.lambert\Application Data\3Dconnexion\3DxWare\profiles\user00.scg
9:33:45.832: UdCtlTransSendSync: AppName=Delcam, sync->opCode=3, sync->itemCode=12
9:33:45.957: udui.cpp:QueryAppForGuiSync: Calling UdCtlSendSync
9:33:45.957: UdCtlTransSendSync: AppName=Delcam, sync->opCode=1, sync->itemCode=2
9:33:45.989: UdUi->AutoSave: Wrote Config File 9:33:45.989: C:\Documents and Settings\wil.lambert\Application Data\3Dconnexion\3DxWare\profiles\user00.scg9:33:45.989:
9:33:45.989: UdUi:TlReadConfigFile: Reading file: C:\Documents and Settings\wil.lambert\Application Data\3Dconnexion\3DxWare\profiles\user01.scg
9:33:46.004: UdCtlTransSendSync: AppName=Delcam, sync->opCode=3, sync->itemCode=12
9:33:46.114: udui.cpp:QueryAppForGuiSync: Calling UdCtlSendSync
9:33:46.114: UdCtlTransSendSync: AppName=Delcam, sync->opCode=1, sync->itemCode=2
9:33:46.114: UdArbitrate: New Target: hWnd: 0x20278, Class Name: Afx:00400000:8:00010005:00000000:00040151, AppName (SiOpen): Delcam, ExeName: pmill.exe
9:33:46.160: s80trans: Memory map underflow error
9:33:47.332: UdUi:TlReadConfigFile: Reading file: C:\Documents and Settings\wil.lambert\Application Data\3Dconnexion\3DxWare\profiles\user00.scg
9:33:47.348: UdUi:TlReadConfigFile: Reading file: C:\Documents and Settings\wil.lambert\Application Data\3Dconnexion\3DxWare\profiles\user00.scg
9:33:47.348: UdCtlTransSendSync: AppName=Delcam, sync->opCode=3, sync->itemCode=12
9:33:47.457: udui.cpp:QueryAppForGuiSync: Calling UdCtlSendSync
9:33:47.457: UdCtlTransSendSync: AppName=Delcam, sync->opCode=1, sync->itemCode=2
9:33:47.457: UdArbitrate: New Target: hWnd: 0x20e00, Class Name: Afx:00400000:8:00010005:00000000:000D0255, AppName (SiOpen): Delcam, ExeName: powershape.exe
9:33:47.457: s80trans: Memory map underflow error
9:38:2.233: UdUi:TlReadConfigFile: Reading file: C:\Documents and Settings\wil.lambert\Application Data\3Dconnexion\3DxWare\profiles\user01.scg
9:38:2.248: UdUi:TlReadConfigFile: Reading file: C:\Documents and Settings\wil.lambert\Application Data\3Dconnexion\3DxWare\profiles\user01.scg
9:38:2.248: UdCtlTransSendSync: AppName=Delcam, sync->opCode=3, sync->itemCode=12
9:38:2.358: udui.cpp:QueryAppForGuiSync: Calling UdCtlSendSync
9:38:2.358: UdCtlTransSendSync: AppName=Delcam, sync->opCode=1, sync->itemCode=2
9:38:2.373: UdArbitrate: New Target: hWnd: 0x20278, Class Name: Afx:00400000:8:00010005:00000000:00040151, AppName (SiOpen): Delcam, ExeName: pmill.exe
9:38:2.373: s80trans: Memory map underflow error
9:38:5.717: UdUi:TlReadConfigFile: Reading file: C:\Documents and Settings\wil.lambert\Application Data\3Dconnexion\3DxWare\profiles\user00.scg
9:38:5.733: UdCtlTransSendSync: AppName=Delcam, sync->opCode=3, sync->itemCode=12
9:38:5.842: udui.cpp:QueryAppForGuiSync: Calling UdCtlSendSync
9:38:5.842: UdCtlTransSendSync: AppName=Delcam, sync->opCode=1, sync->itemCode=2
9:38:5.842: UdArbitrate: New Target: hWnd: 0x20e00, Class Name: Afx:00400000:8:00010005:00000000:000D0255, AppName (SiOpen): Delcam, ExeName: powershape.exe
9:38:5.842: s80trans: Memory map underflow error
9:38:6.561: UdUi:TlReadConfigFile: Reading file: C:\Documents and Settings\wil.lambert\Application Data\3Dconnexion\3DxWare\profiles\user01.scg
9:38:6.576: UdCtlTransSendSync: AppName=Delcam, sync->opCode=3, sync->itemCode=12
9:38:6.686: udui.cpp:QueryAppForGuiSync: Calling UdCtlSendSync
9:38:6.686: UdCtlTransSendSync: AppName=Delcam, sync->opCode=1, sync->itemCode=2
9:38:6.686: UdArbitrate: New Target: hWnd: 0x20278, Class Name: Afx:00400000:8:00010005:00000000:00040151, AppName (SiOpen): Delcam, ExeName: pmill.exe
9:38:6.686: s80trans: Memory map underflow error
