3DxWare software creates settings files all over the place
RedShift
Post by RedShift »
I'm using PTC Pro Engineer Wildfire 4.0 and the 3DxWare software is creating XML configuration files with weird filenames in *all* of the working directories of Pro Engineer. For example:
孷翺
끰ങ
虐ങ
(See attached screenshot)
The content of these files is the same every time:
<?xml version="1.0" encoding="utf-8"?>
<configuration><userSettings><_3dmouse.properties.settings><setting name="3DxPanZoom" serializeAs="String"><value>true</value></setting><setting name="3DxRotation" serializeAs="String"><value>true</value></setting><setting name="3DxDominant" serializeAs="String"><value>false</value></setting><setting name="Speed" serializeAs="String"><value>1</value></setting></_3dmouse.properties.settings></userSettings></configuration>
The version of 3DxWare is 10.4.9. Can this be fixed?
Screenshot of files
Screenshot of files
Re: 3DxWare software creates settings files all over the pla
Hello RedShift,
what language is your Windows and what language is your ProENGINEER Wildfire?
Our driver is not writing the XML files to any folder of ProENGINEER. I assume that these files were created by Wildfire directly. Can you translate the file names?
jaap
Post by jaap »
we have the same problem with Creo 2.0.
Is there any solution??
We use english Windows & Creo.
The filenames are completely random, see picture.
Is there a fix for this??
Jaap
Hi all,
we are tracking this issue with our internal bug number #7389. A fix will be available in the next driver release.
