I run Inventor 11 and Autocad LT. However I would like to use the 4000 at work and the Spacetraveler at home. I cannot do this unless I reinstall the software every time I switch. I also cannot get either to operate with Inventor AND Autocad LT during the same session.
You have 2 different devices you would be limited to using the 5.8.2 driver. No guarentee the driver will work with Inventor 11.
Autocad LT Does not allow Addins, so you would not be able to get the devices to be recognized.
Thanks, it works fine now. I think I had tried to just re-install instead of un-installing the Traveler software and then re-installing the spaceball software.
