When using the Space Navigator (Standard Edition, driver v1.5.0) In Maya 2008 on OS X (10.5.3) with a tool being active (e.g. Split Polygon Tool, Extrude Tool, Append to Polygon Tool etc.) I get the following error message in the Script Editor:
// Error: No valid objects supplied to 'xform' command.
This will be repeated every time I touch the SN
SN Error in Maya 2008
New driver
Have you tried the new driver 1.5.1 ?
Does this still happen or has it been corrected?
driver v1.5.1 doesn't solve the problem
I've installed the latest driver (v1.5.1), but unfortunately, the problem persists.
same error in 1.5.2
Unfortunately, the error still occurs with the latest driver v1.5.2.
So what is the current state in resolving this issue?
