Spaceball 5000 Protocol?
ajmas
Post by ajmas »
I was recently given an old Spaceball 5000 for a study project I am working on. Since I am using MacOS X none of the available drivers were suitable for my needs. Through a bit of detective work I have been able to get the Spaceball to give me ball data, but to save me a bit of time I am hoping someone could clarify some details.
When the ball returns to its center position I get the packet:
dH00H00H00H00H00H00
This represents the movement along the 3 axis and rotation around the 3 axis. This represents the movement along the 3 axis and rotation around the 3 axis. Has anyone worked with this before and worked out:
- which field represent which input
- what the exact format of the field is?
PS I hope posting this is not contrary to forum rules - I couldn't see any mention.
The three translations (X,Y,Z) are sent, followed by the three rotations (X,Y,Z). The data are 16-bit signed integers.
ajmas
Post by ajmas »
Thanks.
4 bytes for a 16-bit integer. The first byte appears to be the sign (H or G), how is the remaining part of the value encoded? From tests I see that the only values for each byte returned are:
.023569:<?ABCDEGHKLMNPSenors
I am guessing BCD or Base26, but then again it could be something else.
I realise I probably asking for a bit much here, but any help would be appreciated.
The data is not encoded from the device. It must be the OSX device driver that is encoding it. See if they have a raw data mode.
