now i am trying to build a static library for spacemouse so that i can simply use it when my application need to connect spacemouse and get data from it. I have two kind of input data A & B, here A means the data getting from spacemouse. if the system detect A is available, application will use A, otherwise it will use data B. I defined a Class named SpaceMouseController, within which I can startup spacemouse and also get data& update state etc.
I am using the old sdk for my spacemouse classic serial, the sdk code was written by C. I built the static lib using the basic code of 3DxTest32(.c), but it can not be linked by my testing application(.cpp). Does anyone have the C++ version(.cpp) for old sdk? I dont know how to solve this problem, please help! THANK YOU in advance!
HOW TO BUILD STATIC LIB FOR SPACEMOUSE?
Hey jwick, thank you for the reply. I'v tried the extern "C", i can build the lib. but when i link it to my test.cpp, some link errors showed up, "error LNK2019:Unresolved External Symbol..." blablabla. i am sorry i really don't know how to change the code to C++.jwick wrote:You can call C from C++ or you can change the code to C++. To call
C from C++, enclose the declarations in an extern "C" {...} section.
can you provide a basic C++ code for old sdk? what i need is only to initialize the spacemouse, connect to and get data from it.
I change the name of 3DxTest32.c into 3DxTest32.cpp, by using this code, I built the dSpaceMouseController.lib. In my test.cpp code, i link this lib file and got this link error:jwick wrote:You are probably getting link errors because you are mangling the names in one place and not in another.
I don't know what code you are using. What are some of the names of the functions?
To change to C++, change the extension to .cpp, compile, and correct any compiler errors <G>.
dSpaceMouseController.lib(3DxTest32.obj) : error LNK2019: unresolved external symbol _SiTerminate, referenced in function "int __cdecl SbInit(void)" (?SbInit@@YAHXZ)
dSpaceMouseController.lib(3DxTest32.obj) : error LNK2019: unresolved external symbol _SiOpen, referenced in function "int __cdecl SbInit(void)" (?SbInit@@YAHXZ)
dSpaceMouseController.lib(3DxTest32.obj) : error LNK2019: unresolved external symbol _SiSetUiMode, referenced in function "int __cdecl SbInit(void)" (?SbInit@@YAHXZ)
dSpaceMouseController.lib(3DxTest32.obj) : error LNK2019: unresolved external symbol _SiOpenWinInit, referenced in function "int __cdecl SbInit(void)" (?SbInit@@YAHXZ)
dSpaceMouseController.lib(3DxTest32.obj) : error LNK2019: unresolved external symbol _SiInitialize, referenced in function "int __cdecl SbInit(void)" (?SbInit@@YAHXZ)
dSpaceMouseController.lib(3DxTest32.obj) : error LNK2019: unresolved external symbol _SiButtonReleased, referenced in function "int __cdecl DispatchLoopNT(void)" (?DispatchLoopNT@@YAHXZ) dSpaceMouseController.lib(3DxTest32.obj) : error LNK2019: unresolved external symbol _SiButtonPressed, referenced in function "int __cdecl DispatchLoopNT(void)" (?DispatchLoopNT@@YAHXZ)
dSpaceMouseController.lib(3DxTest32.obj) : error LNK2019: unresolved external symbol _SiGetEvent, referenced in function "int __cdecl DispatchLoopNT(void)" (?DispatchLoopNT@@YAHXZ)
dSpaceMouseController.lib(3DxTest32.obj) : error LNK2019: unresolved external symbol _SiGetEventWinInit, referenced in function "int __cdecl DispatchLoopNT(void)" (?DispatchLoopNT@@YAHXZ)
Why can not hWndMain & devHdl get value?
SOrry jwick, I have got a new problem.
My test code can not initialize spaceball and connect to it. By debugging the code, i found that my hWndMain and devHdl was always 0x00000000 and didnt change ever. I also debugged demo code 3DxTest32, and found the value of hWndMain changed after execution of " ShowWindow ( hWndMain, SW_SHOW );" and devHdl could also get value after execution of "devHdl = SiOpen ("3DxTest32", SI_ANY_DEVICE, SI_NO_MASK,
SI_EVENT, &oData);".
This is my code. could you help me out?
int
SbInit()
int res; /* result of SiOpen, to be returned */
SiOpenData oData; /* OS Independent data to open ball */
WNDCLASS wndclass; /* our own instance of the window class */
HINSTANCE hInst; /* handle to our instance */
hInst = NULL; /* init handle */
/*init the SpaceWare input library */
if (SiInitialize() == SPW_DLL_LOAD_ERROR)
MessageBoxA(NULL,"Error: Could not load SiAppDll dll files",
NULL, MB_ICONEXCLAMATION);
/* Register display window class */
wndclass.style = CS_HREDRAW | CS_VREDRAW ;
wndclass.lpfnWndProc = (WNDPROC)HandleNTEvent ;
wndclass.cbClsExtra = 8 ;
wndclass.cbWndExtra = 0 ;
wndclass.hInstance = hInst;
wndclass.hIcon = NULL;
wndclass.hCursor = LoadCursor (NULL, IDC_ARROW) ;
wndclass.hbrBackground = (HBRUSH)GetStockObject(WHITE_BRUSH);
wndclass.lpszMenuName = NULL ;
wndclass.lpszClassName = LPCWSTR("3DxTest32");
if (RegisterClass(&wndclass) == 0)
MessageBoxA(NULL,"Error:SpaceMouse Could not register windowclass.",
/* create the window */
hWndMain = CreateWindowA( "3DxTest32", /*Window class name*/
NULL, /*Window caption*/
WS_OVERLAPPEDWINDOW, /*Window Style*/
0,0,215,280,
NULL, /*parent window handle*/
NULL, /*window menu handle*/
hInst, /*program instance handle*/
NULL); /*creation parameters*/
/* display the window */
if (hWndMain == NULL)
MessageBoxA(NULL,"Error: SpaceMouse Could not create message-only window.",
SiOpenWinInit (&oData, hWndMain); /* init Win. platform specific data */
SiSetUiMode(devHdl, SI_UI_ALL_CONTROLS); /* Config SoftButton Win Display */
/* open data, which will check for device type and return the device handle
to be used by this function */
if ( (devHdl = SiOpen ("3DxTest32", SI_ANY_DEVICE, SI_NO_MASK,
SI_EVENT, &oData)) == SI_NO_HANDLE)
SiTerminate(); /* called to shut down the SpaceWare input library */
res = 0; /* could not open device */
return res;
else
res = 1; /* opened device succesfully */
return res;
int
SbInit()
0,0,215,280,
return res;
else
return res;
Jwick, thank you for the reply! I compared my code with the demo code and found that my code was compiled with Unicode. So I just changed it to default and made it compiled again, then my test code works! The reason is that CreateWindow has different meanings under different coding settings. I hope this feedback will help those who may have the same question. Thanks again, jwick. All the best!jwick wrote:If your hWndMain is NULL, your CreateWindow isn't working. A NULL hWnd will cause your SiOpen to fail.
Julian
