SpacePilot confusion between Inventor & Fusion 360
kbmyers
Post by kbmyers »
Hello - I'm having trouble with my SpaceMouse Pro getting confused as to what application I'm running. I primarily use Fusion 360, but I also have Inventor installed. While using Fusion, the SpaceMouse will often stop responding. If I hit the Menu button, I see that the SpaceMouse thinks I'm running Inventor (which is not running).
Without changing anything, if I press ESC and then the Menu button again here's what happens:
The SpaceMouse will then run happily in Fusion for a few minutes before it stops responding again and thinks Inventor is running. This happens every couple of minutes so it is very frustrating.
Any suggestions?
Re: SpacePilot confusion between Inventor & Fusion 360
Hello kbmyers,
we apologize that you encounter problems with your 3D mouse. The issue you reported is a known issue and we are tracking it with our internal bug number #7359. We expect this to be fixed in the next driver release.
For a workaround until the driver is released please contact our Technical Support Team. They can help. ;)
smooker
Post by smooker »
The same appears to me too with the latest SpacePilot drivers.
Hi smooker,
which version of 3DxWare do you have installed?
