SPace Navigator Errors
dschaefer
Post by dschaefer »
I have a Space Navigator that I use with Creo 2 on 64 bit Windows 7. I'm running the latest 3DxWare, version 10.4.10.
I have several issues with my devise that I'd like to solve.
1 - Startup errors.
Frequently on startup I get error messages relating to 3Dx. I almost always get this one saying the server has stopped:
If I get that one, I often, but not always, get this one once I close it:
That one is usually followed by the first again. Once these are dismissed the device seems to work fine.
What is the cause?
2 - Random Files in My CAD directory
My CAD directories are full of 1kb files generated by 3Dx with random, gibberish names:
If I open these in Notepad, they look like XML files. Here is a sample:
<?xml version="1.0" encoding="utf-8"?>
<configuration><userSettings><_3dmouse.properties.settings><setting name="3DxPanZoom" serializeAs="String"><value>true</value></setting><setting name="3DxRotation" serializeAs="String"><value>true</value></setting><setting name="3DxDominant" serializeAs="String"><value>false</value></setting><setting name="Speed" serializeAs="String"><value>1</value></setting></_3dmouse.properties.settings></userSettings></configuration>
3 - Loss of preferences
If I step away from my desk long enough that my screen turns off, when I log back in my Space Navigator doesn't work right. The up/down & right/left axes are reversed. If I open 3DxWare and close it (no need to change settings), it then works fine.
Can anyone help with these?
(BTW - I tried to open a case with tech support but could not because I don't have a support account. I tried to open on, but never got a response back to mny inquiry.)
Doug Schaefer
Concept Engineering
Space Navigator (firmware 4.04, 3DxWare 10, version 10.4.10, 3DxCore version 17.1.0.13926)
Dell M7710
Nvidia Quadro K3000M (driver 362.46)
Windows 7 64bit
Creo 2.0, Creo 4.0
Re: SPace Navigator Errors
Hello Doug,
I apologize that you encounter problems with your 3D mouse. I have searched though all our support requests, but could not find one with your email address. Yes, we are asking our users to create a My3Dx account before that can enter their inquiry. Did you have problems during the creation process?
Now to the issues you reported:
1 - Startup errors
We are tracking this issue with our internal bug number #7390. We will release a new driver with a fix for this issue (3DxProfileServer crash) shortly.
We are tracking this issue with our internal bug number #7389. We will release a new driver with a fix for this issue shortly.
We are tracking this issue with our internal bug number #7365. This issue is still under investigation.
dschaefer
Post by dschaefer »
Thanks for the follow-up. Good to hear these issues are on your radar and looking forward to the new drivers. Is there a way to get notifications of the release of new drivers?
I tried to enter a new case and got the message to create an account. I filled in the form to create an account, submitted it, and I got a message something like "Thanks, we'll be in touch shortly." I never heard anything else.
Doug Schaefer
Concept Engineering
Dell M7710
Windows 7 64bit
Creo 2.0, Creo 4.0
I am sorry, that you never received an answer. Your account was never created in our database. :( If you give it another try I would appreciate your feedback.
dschaefer
Post by dschaefer »
I've tried again, got the same response:
Hopefully it made it into the system this time.
Doug Schaefer
Concept Engineering
Dell M7710
Windows 7 64bit
Creo 2.0, Creo 4.0
