Install Failure - Log files Attached
nicksoph
Post by nicksoph »
Hi
I had installed 3dWare v10.4.10 and intended to try v.10.5.5 but when the old version was uninstalled and the machine restarted, it hung on the shutdown screen and after a few minutes I turned it off. On restart I was unable to either install the old or new versions - receiving a 1604 error code.
Reading thru similar problems it seems this is a permission issue I followed the instructions for running with logging enabled and read thru the log files but cant see how to fix it.
The first error seems to be -
DIFXAPP: INFO: Could not open file C:\WINDOWS\System32\DriverStore\FileRepository\3dxkmj.inf_amd64_103329fde07fdfbd\3dxkmj.inf. (Error code 0x3: The system cannot find the path specified.)
Could someone who understands these things be able to help with instructions of what I should do next?
Best wishes,
nick
Re: Install Failure - Log files Attached
Hi nick,
we need the log files from the installation. I recommend you contact our technical Support Team. They will be able to help you.
nicksoph
Post by nicksoph »
Hi Uta,
Sorry thought I had attached a zip of the log files.
I have followed the link you gave and submitted support request but couldn't see how to attach files to that request. Tried again to add it here.
3DxWinCore64-Install.zip
(142.08 KiB) Downloaded 358 times
nicksoph
Post by nicksoph »
SUbmitted support request on Monday - other than the 'received' email had no reply.
Can anyone tell me if this is normal - should I just be patient?
nicksoph
Post by nicksoph »
Received reply - run ms fixit program - not fixed but in comms
Hi nicksoph,
we will come back to you with a more detailed procedure how to fix the issue. Please bear with us for a while.
nicksoph
Post by nicksoph »
Fixed by reinstalling Windows using Windows Refresh and then installing 10.4 driver
