Hello
I use a USB cadman solidedge 64b v20 on XP. The driver starts properly 3dxs taking the version of 64b by cadman cons I just can not install the plugins Solidedge in this configuration. The plugin is not loaded at startup solidedge. Should he install a different version of the plugin in this configuration?
Thank you for your reply.
Nicolas
Cadman SolidEdge v20 64b plugins don't start.
Nplanchenault
Nplanchenault
SolidEdge v20 plugins don't start
Cadman working properly but I can not find a version of the plugin that works with Solidedge
Solidedge 64bits v20. I have already worked this configuration in the past by installing a version
different driver and plugins. I can not find the versions that I installed at the time.
Nicolas
Nicolas
