button values from 3d space mouse
Re: button values from 3d space mouse
Post by jwick » Wed May 05, 2021 1:32 am
Unless I'm missing something in your code, you don't have any Keyboard event handlers.
E.g.,
Private Sub Keyboard_KeyDown(ByVal keyCode As Integer) Handles Keyboard.KeyDown
Me.SetKeyText(keyCode)
End Sub
Private Sub Keyboard_KeyUp(ByVal keyCode As Integer) Handles Keyboard.KeyUp
End Sub
AntonyAlbertAnto
Post by AntonyAlbertAnto » Wed May 05, 2021 3:08 am
no I do not have any such code line.
AntonyAlbertAnto
Post by AntonyAlbertAnto » Wed May 05, 2021 3:09 am
If I am using those code line, will I be able to see the values from buttons.
Post by jwick » Wed May 05, 2021 4:00 am
You need handlers for the button events.
The exact code lines above came from our vb sample code.
You probably need to do something different with the values when you get them. For now, I'd just print them out.
AntonyAlbertAnto
Post by AntonyAlbertAnto » Wed May 05, 2021 6:15 am
Hi Jwick,
So is there an example for handlers for the space mouse buttons in vb
Post by jwick » Wed May 05, 2021 6:37 am
I'll email a project to you.
I assumed you had it because some of your code looks like it came from it.
Let me know if you don't get it. Sometimes these things get blocked by firewalls.
Well, I tried. Your email server bounced it back. I'll try a link.
AntonyAlbertAnto
Post by AntonyAlbertAnto » Wed May 05, 2021 9:19 am
Jwick, Did u send me the link. I haven't got an email or link.
Post by jwick » Wed May 05, 2021 11:36 pm
I didn't get a message that the link email bounced.
I've now sent you a PM.
AntonyAlbertAnto
Post by AntonyAlbertAnto » Thu May 06, 2021 3:17 am
Hi Jwick,
Thanks for the link. I was able to see the translation, the rotation and the angle, but still nothing happened when I pressed the buttons of the space mouse. No value showed in the keydown box.
AntonyAlbertAnto
Post by AntonyAlbertAnto » Thu May 06, 2021 3:29 am
Hi Jwick,
Do I need to assign any function to the button to see the values before running the program?
Post by jwick » Thu May 06, 2021 3:43 am
By default the side buttons are mapped to driver radial menus.
You need to open our GUI when the application is running and map your buttons to actions that send an event to your application.
E.g., if I am running the vbMonitor sample:
I open our GUI (3DxSmartUI - 3Dconnexion Properties),
select my device,
go to the Buttons page,
select a button,
go to the vbMonitor category
select Back View.
When I press the button I assigned Back View to, I get an "8" in the Key Down TextBox.
AntonyAlbertAnto
Post by AntonyAlbertAnto » Thu May 06, 2021 6:07 am
Hi Jwick,
Thanks I am able to see the values while press the buttons.
Post by jwick » Thu May 06, 2021 6:12 am
Glad you have it working.
If you want different information for those button presses (e.g., "1", "2"), you can create a cfg file for your application.
AntonyAlbertAnto
Post by AntonyAlbertAnto » Fri May 07, 2021 3:13 am
Thank you Jwick for your support. I am able to the see the values 1 and 2 while I press the buttons.
Thank you
