Hi.
Can the pivot display be turned off?
The pivot remains after using the spacemouse in AutoCAD.
Thanks.
Pivot display
Re: Pivot display
Hi MarianoGH ,
What do you mean exactly? What's the version of AutoCad and the driver you using?
If you can provide more details or a short video of your issue then I might be able to help
Regards,
Abdul. A
Regards,
Abdul. A
Re: Pivot display
Hi, aalsalihi.
Thanks for answering.
Not that it is a malfunction problem. I just want to know if I can disable the Pivot because it is so annoying.
