Using two different mice on the same laptop
simcentervsfemap
I use a Spacemouse Compact at work, but I'm thinking about buying the older SpaceNavigator for my WFH setup. Will they be compatible if I'm using them on the same laptop?
Re: Using two different mice on the same laptop
They will both work. You can freely plug and unplug them as needed.
They do not share the same settings though. Any settings (button assignments) you make for the SpaceNavigator will not be applied to the SpaceMouse Compact, and vice versa.
The only difference is that SpaceNavigator will not be supported by future 3DxWare driver some time next year.
simcentervsfemap
Thank you all
