Terminology ambiguity
Hypersonic
Post by Hypersonic »
Some of the 3DConnexion's directional terms I feel are a bit ambiguous, such as Spin and Tilt, which in other contexts could mean rotation in any direction. Zoom is a bit confusing as well, as pan up/down is usually used to 'zoom' in Google Earth. Perhaps there could be an option to display actions in aeronautical terms instead, for those familiar those terms.
http://en.wikipedia.org/wiki/Flight_dyn ... ircraft%29
Translate/Move ALONG Z axis or Tz
pan up down (3Dconnexion)
Vertical (aeronautical)
Translate/Move ALONG X axis or Tx
pan left right (3Dconnexion)
Lateral (aeronautical)
Translate/Move ALONG Y axis or Ty
zoom (3Dconnexion)
Longitudonal (aeronautical)
Rotate AROUND Z axis or Rz
spin (3Dconnexion)
Yaw (aeronautical)
Rotate AROUND X axis or Rx
tilt (3Dconnexion)
Pitch (aeronautical)
Rotate AROUND Y axis or Ry
roll (3Dconnexion)
Roll (aeronautical)
Thanks for your consideration, and awesome product!
Thanks for the feedbak, Hypersonic.
We use those terms internally but experience has taught us not use them in a personal computer context. "Spin" and "tilt" are terms most have of a sense for. Aeronautical definitions are precise but very technical.
OTOH, Hypersonic, with 3DxWare 10, you can change those terms to anything you want.
Hypersonic
movement names
I understand what you mean. I suppose terms such as spin and tilt sound more approachable to users unfamiliar with the device.
jwick, do you change the terms in Base.xml, or possibly 3DxConfig.xml ? Or another file?
Those strings are in en-US_def.xml.
Hypersonic
Thanks for the info.
I suppose the term 3Dmouse was coined because when people hear/see the term 'joystick' they probably envision a large unweildy controller with only a few axis of control, not 6.
However, to APIs such as DirectInput, 3Dmouse and joystick both utitilze the same variable/function names, I assume? The 3Dmouse Rx (tilt), for example, is the same to the input API as Joystick Rx? So if joystick Rx didn't work for a particular app, nor would 3Dmouse Rx (tilt) ?
No names works everywhere. Everyone has their own definition, description or orientation. So far the only thing I've NOT seen is to call a rotation a translation....nope, see that all the time...
That's why I exposed the names in XML. Name them whatever works for you. I'm done making decisions :)
