Hi, I'm considering buying a SpaceNavigator to solve a problem, but I want to be sure it can do the following (with a properly set up cfg, of course).
For a given axis, can I send different outputs based on the axis amount? Secondly, can I send mouse and keyboard events for the same axis event?
E.g. for a given axis that's generating 0...MAX values in a given direction:
0...a, send nothing (deadzone)
a...b, send "w"
b...c, send "SHIFT+w"
c...MAX, send 'mouse right button down' and "w"
Is that possible?
KMJ: output different values for different axis amounts?
donmacquarrie
Re: KMJ: output different values for different axis amounts?
Yes, you can do that. If not with the built-in interface, with some extension code.
It's another question as to whether you will be able to predictably generate all those different ranges.
