I noticed that if I uncheck a degree of freedom for the 3DEXPERIENCE app, the other two similar degrees of freedom can no longer be used, even if they are not unchecked in the advanced settings. So if I uncheck sideways translation, and the other two are still checked, I am unable to use any translation in the software, it's like the mouse is not sending any translation anymore. It's similar to rotation, which means that if I uncheck one translation and one rotation the mouse no longer does anything. Have you encountered this issue before?
Unchecking a degree of freedom in 3DEXPERIENCE will make the other two unavailable
