Maya "Move Objects" setting shortcut/macro
When using the SpaceMouse Enterprise with Maya there is an option in "Other" in settings to tick a box ("Move Object")to enable the movement of selected objects within the viewport using the joystick. However this requires many steps and mouse clicks. Is there a way to create a shortcut or macro to quickly toggle that option on or off with one click ? It doesn't seem possible to create the macro using the 3Dconnexion settings. Would I have to change the .xml script and if so how ? Also when the "Move Objects" option is ticked it is no longer possible to orbit or navigate around a selected face or vertex, is there a fix for this ?
