Auto Centering completely broken in 3ds Max
So for some reason the auto centering function has been broken for a long time now, and the only working driver i can use that it isnt is 10.7.0. So basically it fails to auto center correctly and centers on random things or in the void awkwardly, or if an object is infront of and there is a plane behind it, it will auto center behind the object in question. I use this auto center feature heavily and i always try each new driver update hoping it gets fixed, but this problem still persist so im forced to use an old driver which is 10.7.0. If there is a fix for this I would very much appareciate it, if not ill just keep waiting to see if it ever gets fixed. Cause it seems like 3ds max is the forgotten child since it works fine in everything else for me.
