ESC, Shift, Alt, CTRL not working over RDP
fylson
Post by fylson »
Hi, i am working at home over windows remotedesktop. (The PC stands right next to me, but i only use one set of monitors, thats why i am using rdp).
I using a Spacemouse Pro Wireless and plugged the wirelesstransmitter directly into the remotepc itself (not working if i am using it in my normal pc, even with some instructions from the internet).
Everything works fine but these 4 keys not working. I reading somewhere this could be, because some "virtual keyboard"-errors. Is this the issue? If i am using the virtual keypad function, it shows to me, or is this an other thing?
Did someone know a solution for it?
Window Remote Desktop (Windows 10)
Spacemouse Wireless Pro (Plugged into Remotedesktop)
Re: ESC, Shift, Alt, CTRL not working over RDP
You can try adding this to your %appdata%\3Dconnexion\3DxWare\Cfg\Global.xml file
<KMJMechanism>SendInput</KMJMechanism>
as shown in this post
fylson
Post by fylson »
Hi jwick,
works like a charm, big thanks for this. :)
fylson
Post by fylson »
works like a charm, thank you very much.
