SketchUp keeps on dropping the Camera mode in favor of Target Camera mode.
sunflovver
Post by sunflovver »
I work in SketchUp and often switch between parallel projection and perspective. I feel comfortable with the CAMERA mode. It is really annoying that when I switch back to perspective, I have to manually turn off the TARGET CAMERA. Is there a way to disable the target camera in perspective?
I think a few years ago there was no Target camera mode in SketchUp. Life was better then.
Re: SketchUp keeps on dropping the Camera mode in favor of Target Camera mode.
If you're using "Camera" (or "Fly" mode) in a perspective view and then switch it to orthogonal projection, the software has to change to "target camera since that's the closest mode than can be used in a parallel projection (the camera cannot "fly" in a parallel projection, only target camera will work).
sunflovver
well, that's really annoying, especially considering that it was not happening in the early releases
sunflovver wrote: Fri Aug 11, 2023 7:00 am especially considering that it was not happening in the early releases
Are you positive about that? We have had this behaviour since around mid-2019, over four years ago now.
sunflovver
perhaps I was not updating my drivers.
oh, perhaps I can just roll back to an old driver
