Hi!
My SpaceMouse Pro is not working with C4D 2024, works fine with C4D 2023.
I've uninstalled and reinstalled the 3dconnection driver, on the 3dconnection app it calls C4D "Default-KMJ" and doesn't work.
How do I fix this? Do 3Dconnection need to fix this with a patch?
Thanks for your help!
SpaceMouse Pro not working with C4D 2024
Re: SpaceMouse Pro not working with C4D 2024
Looks like Cinema 4D is not loading the plug-in.
Please ensure you are using 3DxWare 10 v. 10.8.16 or newer. The software is available for download here.
If you already at v. 10.8.16, then you may want to get in touch with our Technical Support team (contact details here).
