unreal engine 5.4 support
jlo
Post by jlo »
I tried loading the 5.3 driver but it's not working. It wont even load unreal now saying the TDxUnrealEditor failed to be found.
I created the marketplace and 3dconnexion folder as per prior instructions. I also changed the engine version in the TDxUnrealEditor.uplugin but it was a nogo.
Changing "EnabledByDefault": false, at least allows unreal to load.
Running 3dxware version 10.8.19.3708 (currently up to date)
DavidV
Re: unreal engine 5.4 support
Post by DavidV »
jlo wrote: Sat Mar 23, 2024 3:02 am I tried loading the 5.3 driver but it's not working. It wont even load unreal now saying the TDxUnrealEditor failed to be found.
Hello jlo,
We do not have support for 5.4 yet. You also tried the same work around I would have tried but it seems it will not work. WE are working on another driver and it should support for 5.4
jlo
Post by jlo »
Ty
claaudius
Post by claaudius »
Can you give us an estimate for when the driver will be available?
Thank you!
We have had support available for UE 5.4 available since quite some time but it was available to those enrolled in the Insiders programme.
The plug-in for UE 5.4 is available from the Unreal Engine Marketplace (web page here). It was published today, April 24.
sparkyj
Post by sparkyj »
Where can we go to modify the behavior of the Space Navigator inside Unreal Editor 5.4? There is no drill-down in the plugins section for swapping the direction of the moves, I.E: up is down, left is right. Everything is reversed. I have posted in other threads seeking clarification. Thanks for any help.
